I recently installed the enhanced sound system amp on my 1999 Ultra, kit number 77176-01A. The part number of the amplifier itself is 77179-01. It was a pretty simple install since everything is plug and play. When I turned the radio on, I'm only getting sound from the front speakers, nothing from the rear. I've tried adjusting the front to rear fader and it makes no difference. I can't run my bike right now since the gas tank is off and I'm doing other work, but I'm wondering if the bike has to be running to supply enough power to the amp to make the rears speakers work. I doubt this is the case and this might seem like a dumb question, but I'm grasping at straws trying to determine what the problem might be. Is there anyone else out there with this system that can confirm if the front and rear speakers work without the engine running?
YES THEY WORK WITHOUT THE ENGINE RUNNING. CHECK YOUR CONNECTIONS CAREFULLY AND FOLLOW THE INSTRUCTIONS.BE CAREFUL WITH THE SIDE PLUG.SORRY I CANNOT BE OF MORE HELP BUT A DEALER INSTALLED MINE ON MY 03.
Before I went to the dealer I'd check the output of the amp on the rear speakers. If you have a SM you already have the pin assignments and wire color information. Assuming you don't, the left rear speaker (+) is Brown in pin 10 of the Ultra plug; and (-) is white/brown stripe in pin 3; the right rear speaker (+) is Green in pin 11; and (-) is Light Green/brown stripe in pin 4.
Assuming the amp is providing power to those circuits, I'd check the speaker wiring.
Sorry to hear of your trouble; hope you find a solution.
I am looking to install this amp on my 03 Roadglide. I have picked up some rear speakers and was looking for some written directions on how to install it on a 99 - 05 touring bike.
PM me an email address where I can send you the instructions.
I have 2001 HD FLHT Standard with the amp 77179-01 and no sound is coming out. I saw you had instructions to install it, do these include a wiring diagram? Can you tell me what and where we need to check to find the solution?
