Avon Venoms
Old Mar 30, 2008 | 01:07 AM
hwyjunkie's Avatar
hwyjunkie
Default Avon Venoms
Just wanted to let you guys know i just put a set of Avon Venoms on my bike with a 150/80/16 on the rear. I must say that the ride and handling are superb. If any one isready for tires i highly recommend the Avon's. Oh by the way I have a 2007 RKC
Old Mar 30, 2008 | 01:09 AM
DiegoKing's Avatar
DiegoKing
Default RE: Avon Venoms
Yeah, I had Venoms on both my previous scoots and loved them. When my King is ready I will be putting them on it.
Old Mar 30, 2008 | 01:13 AM
Jumpman's Avatar
Jumpman
Yep... Same set-up on my RK.
Great tires.
Old Mar 30, 2008 | 03:26 AM
Abnmarine's Avatar
Abnmarine
I run them and they are a great tire. Mine are 18"'s and are a big improvement over stock.
Old Mar 30, 2008 | 05:38 AM
Badbagger's Avatar
Badbagger
Gotta agree. They supposedly came out with a new tread pattern so I ordered them in 18's. I've run Metzlers for years but I am really liking these.
Old Mar 30, 2008 | 05:40 AM
HarleyLew's Avatar
HarleyLew
Do they carry White Walls in the venom series?
Old Mar 30, 2008 | 05:52 AM
Jrsess's Avatar
Jrsess
I had Venoms on an older metric and loved them. Plan on more when the SG is in need.
Old Mar 30, 2008 | 05:59 AM
WildBill2566's Avatar
WildBill2566
ORIGINAL: hwyjunkie
I thought about those but chickened out and stuck with the Venom 140/90B16 77H, did you use the 77 H or the 77 V rated tyre, just curious because one is 150 mm (5.9")true width and the other is 157 mm (6.2") true width. I know either would be fine as the 77 V exceeds the specs of the 77 H.
What is the clearance like on the RKC (Is that Classic or Custom). I am guessing that the limiting point is belt to tyre clearance. If you get the chance I would be keen to know the actual measurement.
Just asking because I may follow your lead when I replace the rear.
WB
Old Mar 30, 2008 | 06:01 AM
WildBill2566
ORIGINAL: HarleyLew
Yes follow the link below. WW denotes white walls.
http://www.avon-tyres.co.uk/motorcyc...specs&id=1
Hope that helps.
WB
Old Mar 30, 2008 | 08:05 AM
barkster99's Avatar
barkster99
I'm one more with RK Classic that switched to Avons just a couple weeks ago. Very pleased so far. Anxious to get some more miles on them. Curious of that tread pattern in the rain and bridge grates.
I'm also curious about the fitment of 150/80/16 rear instead of 140/90/16. Clearance is ok with no modifications? Any speedometer deviation?
Mine are 77H, WW. Didn't see any 77V option. Maybe not available in the WW?
By the way, found best price with Dennis Kirk, about $260, and another $50 to local shop for mount/balance.
