ECM code determined...now what?
Old Mar 31, 2008 | 05:57 PM
a21m's Avatar
a21m
Default RE: ECM code determined...now what?
yes, factory wires
Old Mar 31, 2008 | 07:05 PM
choochoo's Avatar
choochoo
If the problem existed before and new plugs and wires did not cure and
you are sure they are right ones and are connected correctly.
You need to go to the next easiest step.
Get an inline spark checker.
Connect it between the wire and the plug, do you have a good spark?
no..... bad new plug wire or plug, bad connection of primary wire to the coil,
faulty coil, bad wire from ECM to coil, bad ecm
or...... do compression test confirm good compression.
Faulty injector. not spraying fuel or the correct amount.
The list can get deeper and more intense.
harryr
Aug 15, 2010 06:12 PM
agapsdiver
Electrical/Lighting/Alarm
Dec 26, 2008 04:07 PM
stagolee
Apr 21, 2008 10:51 PM
SalsaNChips
Mar 19, 2008 07:07 AM
combat_vet
Screamin Eagle CVO Models
Jun 9, 2007 02:02 PM
