starting
Old Apr 2, 2008 | 09:21 AM
cirhere2's Avatar
cirhere2
Default starting
New to 07 Ultra classic it will not start unless it is in neutral
even if you pull clutch in all the way it will not start put it in neutral and starts right up
Russ
Old Apr 2, 2008 | 09:25 AM
drrandall1's Avatar
drrandall1
Default RE: starting
Hmmmm. I was going to go try it on my SG but it's at the damn shop getting painted.. I miss it!!!
Old Apr 2, 2008 | 09:27 AM
stro1965's Avatar
stro1965
The clutch safety switch may be broken. It's in the clutch side housing and looks much like the brake light switch in the right housing. Have you taken the housing apart to change grips or anything?
Old Apr 2, 2008 | 09:29 AM
drrandall1's Avatar
drrandall1
thought that seems odd
Old Apr 2, 2008 | 09:34 AM
sweet07's Avatar
sweet07
my bike won't start if'n it ain't in neutral
Old Apr 2, 2008 | 09:53 AM
rochkes's Avatar
rochkes
my 08 will start in gear as long as the clutch lever is pulled. I would also guess that the switch on your clutch to over ride the neutral start safety isn't working.
Dennis
Old Apr 2, 2008 | 10:02 AM
OldArmy's Avatar
OldArmy
Same, starts in any gear. All the same, just can't bring myself to hit the button unless the clutch is in, even with a big green "N" showing. Don't ask why...
[IMG]local://upfiles/35632/8D03062A976C4B25ABA59B852D6F5305.jpg[/IMG]
Old Apr 2, 2008 | 10:03 AM
real7jake's Avatar
real7jake
ORIGINAL: rochkes
Dennis
+1
Old Apr 2, 2008 | 10:19 AM
Grizzled's Avatar
Grizzled
Switch is defective or misadjusted, should start in any gear, as long as the clutch lever is pulled in.
Old Apr 2, 2008 | 10:29 AM
drrandall1's Avatar
drrandall1
IT should have a clutch safety switch
