I have a license plate trim kit with the run, turn, brakelights (2 wire set up).I need to know where to hook this up at as there is no instructions and the ends have been cut. Also can I wire my tour pak lights up to be brake lights along with theturn signals, tail lights.
Under your seat there is a plug you will see where it goes back to the back of your bike...If you dont have a service manual you wil have to use a light tester to see witch wire is what....I think you might mean this when you say you want lit up???
Thanks White Night, I have been soldering wires in, got tail lights and one turn signal so far. I didn't check to see if brake light worked on the same side as turn signal when it is off. I like your lite setup. Where did the trilite come from? I thought about the bag lights but have not seen a set hooked up in person yet. May be my next project. Thanks for the info. I hope I am doing this right. Soldered and heat shrinked all connections. Will be putting quick connect at the light itself. Again thanks for the reality check.
The tri setup came from ebay bought it and modified to fit my application I have the three wired to work as turn run and brakes along with the turn signals and regular brake light, the barlight in the center is on all the time...And your trip pack is on another circut of its own... I have the bag lights wired so they are on all the time.... It's a real ******* but just take your time and it will come around...Good Luck, Jer
