cam advice
Old Apr 2, 2008 | 08:05 PM
BM83's Avatar
BM83
Default cam advice
I am planning on changing the cams on my 2007 96" road glide. I have rhinehart true duals, SE air cleaner, and Race tuner. Everything else is stock. What would be a good choice? I have been told that the SE 255 would be good. I was wondering if the HQ 575 would be too big? I could always use that cam if / when I decide to go with a 103.
Old Apr 2, 2008 | 08:17 PM
dawg's Avatar
dawg
Default RE: cam advice
HQ500, WoodsTW6, Zippers redshift 575, Andrews 54
Old Apr 2, 2008 | 08:20 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: dawg
Only other one I might throw in there would be the R&R525...........but there just isn't a lot of info or people using it.
Steve
Old Apr 2, 2008 | 11:50 PM
Harleypingman's Avatar
Harleypingman
Give Kevin at HQ a call regarding the 575 and 500 HQ cams. He may tell you that with the 575 running stock heads you will be over-cammed. Also, with the 575 lift cams it may be prudent/necessary to use a stiffer valve spring. Also, IIRC a dealer did a direct comparison between the SE 255 and HQ 500 cams and the HQ delivered a broader torque curve and more hp.
Old Apr 3, 2008 | 09:56 AM
scootertramp's Avatar
scootertramp
Throw in thwe Andrews 37H. You can run em stock or at 103" with a mild compression upgrade. Real nice torque from around 2100 up.
Old Apr 3, 2008 | 07:00 PM
BM83's Avatar
BM83
I am leaning toward the HQ 500. The only reason I was thinking about the HQ 575 was so I would not have to buy another cam when I go 103. I really don't want to over cam.
Old Apr 3, 2008 | 07:13 PM
dawg's Avatar
dawg
The 500 will work in a 103 also. Not optimum like the 575 but it will be fine
Old Apr 3, 2008 | 08:00 PM
rahall's Avatar
rahall
I have a very similar setup as yours.
I went with the HQ 500 cams.
That a look at this thread.
https://www.hdforums.com/m_2825599/tm.htm
Old Apr 3, 2008 | 08:22 PM
Xtreme's Avatar
Xtreme
hq all the way baby
Old Apr 4, 2008 | 03:24 PM
empireking13's Avatar
empireking13
im having a 103 built with gerolomy wa3 heads and im useing a woods 9fg cam. should produce big numbers!
