Plug wire change
Old Apr 4, 2008 | 07:28 PM
caorig's Avatar
caorig
Default Plug wire change
Bought a new set of plug wires and read the shop manual in regards to replacing them. I am having trouble getting to the coil to disconnect the old wires, let alone install the new ones. The shop manual does not mention removing the gas tank, but I'm thinking that may be necessary. Does any of you have a tip on performing this task?[:@]
Old Apr 4, 2008 | 07:34 PM
dawg's Avatar
dawg
Default RE: Plug wire change
Loosen the tank and lift it up without removing it and you should be able to get to it.
Old Apr 4, 2008 | 07:43 PM
jag1886's Avatar
jag1886
I put a set of Magna Core wireson my 07 RC and I did need to removethe front tank bolt to get enough room to grab the and wires to pull them off.
Old Apr 4, 2008 | 07:45 PM
Xtreme's Avatar
Xtreme
I agree take the front tank bolt out and lift it a bit,
Old Apr 4, 2008 | 07:57 PM
xxxflhrci's Avatar
xxxflhrci
I use pistol grip needle nose pliers.
Cozz
May 28, 2018 03:06 PM
creep1
Apr 15, 2015 01:05 PM
Bushy
Feb 4, 2015 02:02 PM
jacknthebox
Sep 5, 2011 07:17 PM
sppxl0
Sep 25, 2008 09:49 PM
