I want to run this past you all.
I have an 08 SG and have tried multiple times unscrewing the stock antenna so I can replace it with a shorter style for now.
I read here were the 07 SG has a set screw you loosen and the antenna just screws off.
Am I loosing it or does the 08 antenna just spin and not come off?
thanks in advance.
There is no set screw on my antenna.
I did however get it to work.
I cut back the rubber boot exposing a spring and pulled the stock antenna off.
Cut a piece of the shield off which exposed the threaded screw.
Screwed on short antenna and good to go. I did add some heat shrink tubing to dress it up real nice.
