New noise after doing 3 hole oil change
Old Apr 7, 2008 | 08:22 PM
rfp1954's Avatar
rfp1954
Default New noise after doing 3 hole oil change
Just got done doing a 3 hole oil cange using Mobil V1 20-50. My bike is a '02 EG. Bike was due for a oil change. Bike ran fine before with no noises. Put in the recommended amouts in all 3holes. Started the bike up and let if warm up. Then droveit about a mile. Came back tocheck fluid levels. Started to here awhineor strange noise that seems to come from the primary. Check engine and trans fluid levels and both are fine. I did notice that when I put the 32 oz in the primary it seem low and hard to see under the clutch.But that is what the manual say to put in. Wondering if any has had this happening to them. I don't want to over fill the primary but maybe it need more. Appreciate any suggestions. Thanks
Old Apr 7, 2008 | 08:27 PM
harpoon's Avatar
harpoon
Default RE: New noise after doing 3 hole oil change
RFP, I am sorry but i can't answer your question, but maybe you can answer one for me. I don't understand when people say they are doing an "3 hole oil change" can you explain please?
Thanks alot
Harpoon
Old Apr 7, 2008 | 08:31 PM
Beemervet's Avatar
Beemervet
ORIGINAL: harpoon
Thanks alot
Harpoon
Gearcase, tranny, primary.
You put 20/50 in all three?
Old Apr 7, 2008 | 08:42 PM
harpoon's Avatar
harpoon
So are you placing the same fluids in each of these holes? I thought all the 3 holes took different fluids. and what does 20/50 mean.. Sorry if I sound dumb just trying to learn.
Thanks
Harpoon
Old Apr 7, 2008 | 08:43 PM
Retired_Ted's Avatar
Retired_Ted
Did you check the primary chain tension?
Old Apr 7, 2008 | 08:50 PM
StreetglideOK's Avatar
StreetglideOK
Instead of using exactly what the manual says for fill quantity, use it as a guide. It may take more, it may take less, but close to that usually. Fill the primary to what is considered full when you check it. Doubt it is a factor with your noise though, just food for thought.
Old Apr 7, 2008 | 08:56 PM
dawg's Avatar
dawg
When is the last time you checked the chain deflection? I use the liot tool and it works like a charm, others have made a similar tool successfully.
RogueHD
Oil Archive (no new posts)
Sep 19, 2015 10:00 AM
mkrohn151
Engine Mechanical Topics
Apr 26, 2015 12:04 AM
mkrohn151
Oct 10, 2014 07:47 AM
EdGlide
Apr 4, 2008 03:33 PM
1200frk
Oct 5, 2007 08:49 PM
