I am about to install Python True Duals, Python Pipes, Arlen Ness Big Sucker, and V&H FuelPak on a '08 Street Glide. Are there any clamps (additional parts) that I need to buy? What about special tools? Does anyone know what the torque values are for where the pipes connect to the engine?
Make sure you buy new head gaskets, its imperative, dont ask me how I know. Your also going to need "O" ring pliers. Good luck its not that bad of an install.
Streetmed
06 Streetglide (vivid black)
V&H Bigshot true duals (shark fin end caps are bad azz)
K&N High flow
PC III
Chrome chrome and chrome
Red Knights Southeastern PA Chapter II
PGR
+1 on the snap ring pliers and gaskets. I don't remember the torque value on the head bolts I think it was listed in the instructions. Its a pretty easy install get an extra set of hands if you can.
About the Big Sucker. I did a loose "mock-up" of the backplate and all hardware for thread quality. I found that when I tightened the bolts that secure theback-plate to the cylinders, the stand-offs for the filter did not line up. I backed the cyl. bolts off and installed the long filter mount bolts and aligned them. Then went back and tightened the large bolts.Other than that, the install went well.
