What tha?!?
Old Apr 11, 2008 | 03:34 PM
Zimbob's Avatar
Zimbob
Default What tha?!?
Heres the deal. Rode to work last night, scoot ran great, parked it and went to work. Came out to leave this morning, and NOTHING. Tha lights are good and bright, the guages and idiot lights work just fine, fuel pump cycles like it shoutd, all I get is a small click from the starter relay. I tried chamging the relay, same thing. I thought maybe the PCIII was shot, bypassed it, same thing. Everything else on the scoot works fine, she just won't do squat when I hit the start switch. The dealer has it now, I'll post a follow up whenI get her back. The only mods so far is a breather, exhaust, and PCIII, '07 Raod king, mods done at 500miles, 10,000 now.
What do you guys/gals think the problem might be?
Old Apr 11, 2008 | 03:45 PM
texan321's Avatar
texan321
Default RE: What tha?!?
Gosh seems to me the the dealer will tell you..
Old Apr 11, 2008 | 03:57 PM
Jinks's Avatar
Jinks
Battery/starter/loose wire
Old Apr 11, 2008 | 04:04 PM
krazy3's Avatar
krazy3
ORIGINAL: Jinks
Ditto. I had a battery 'break' a cell once and that's all it would do. Couldn't jump it, couldn't charge, nothing.
Old Apr 11, 2008 | 04:30 PM
mrsr71's Avatar
mrsr71
It's probably the wigelrwertz switch.
Old Apr 11, 2008 | 05:55 PM
Yogibear's Avatar
Yogibear
Is that attached to the foofoo valve?
Old Apr 11, 2008 | 06:05 PM
mrsr71's Avatar
mrsr71
ORIGINAL: Yogibear
Exactly - just above the blinker fluid drain valve.
Old Apr 11, 2008 | 06:31 PM
1Harleyrdr's Avatar
1Harleyrdr
I think it is the Starter switch on the Bars. If the contcacts corode they do just as described.
Did your headlight go out when you pressed the starter button?
Old Apr 11, 2008 | 06:50 PM
Superglide 04's Avatar
Superglide 04
Bad Starter ground.
chiefaponte
Mar 13, 2013 02:23 AM
chiefeng
Sep 18, 2010 03:36 PM
TurkeyRun
Jun 22, 2009 12:01 PM
zenwarrior
Sep 28, 2007 10:20 AM
4Scott4
Jul 16, 2007 09:31 PM
