Rewiring for cruise on bars
Old Apr 11, 2008 | 10:25 PM
tna1000's Avatar
tna1000
Default Rewiring for cruise on bars
I am going to do some custom bars on the RK and want to do all push button controls. Question is, how do I wire up the cruise to work on buttons. The on/off swith would be easyI assume but not sure on the set/ accel and the cancel/decel swithes that are on the factory controls. Any ideas. Thanks
Old Apr 12, 2008 | 12:01 AM
roadtrash56's Avatar
roadtrash56
Default RE: Rewiring for cruise on bars
You can use a three wire set up. You will have two leads to each button, one of which will be common between them. Really simple. When I mounted the cruise on my 99 FLHRPI, couldn't get the controller for it without buying a whole harness for 200. Used the horn/siren switch which has a sepreate lead for each side and a common connector in the middle. Worked great and now extra wires floating around.
Old Apr 12, 2008 | 08:45 AM
tna1000's Avatar
tna1000
What did you do for the set and decel switches. I know it can be done. My truck is on buttons. I just assumed that when I buy push buttons for my bars they would only have 2 leads. May be wrong though.
svu0312flhx
Nov 14, 2012 08:34 AM
emperor wurm
Oct 13, 2011 10:34 AM
Fire-Medic
Feb 14, 2011 05:54 PM
juscoop
Mar 25, 2010 08:38 AM
