Detatchable Tour pack rack kit
Old Apr 12, 2008 | 12:36 AM
08HD's Avatar
08HD
Default Detatchable Tour pack rack kit
Has anyone installed one of these, and if so was it pretty easy? Also, did it connect well with no movement when it is in the docking kit?
Old Apr 12, 2008 | 02:30 AM
Matt8643's Avatar
Matt8643
Default RE: Detatchable Tour pack rack kit
I installed one on my RK and it was fairly simple and there is absolutley no movement. I am satisfied with it.
Old Apr 12, 2008 | 02:41 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
I installed one on my 07 FLHTC and am very satisfied so far. I used the kit from the MOCO
HD pt.# 53303-07 and found it complete with everything needed.
Supposedly, the black nylon bushings wear over time and the rack will start to rattle. There are several alternatives when they do.
Old Apr 12, 2008 | 05:02 AM
bobmurdy's Avatar
bobmurdy
Hi Bud, Ive installedon my FLHT both the tour pack two up and for single seat and both fittings are rock solid. Found the single seat fitting can be a bit fiddley to snap on if you don't remove the side panniers but all in all 10 out of 10 for a great system (you are paying for quality and convenience).
Bob
Old Apr 12, 2008 | 05:56 AM
Peppa1's Avatar
Peppa1
I have installed it on my last 3 baggers and it's easy and works great. Esay off and on.
Old Apr 12, 2008 | 06:00 AM
blackfinbob's Avatar
blackfinbob
No problemos here either. Once you get the hang of putting it on and taking it off, it's a 10 minute job......
b
Old Apr 12, 2008 | 10:44 AM
08HD's Avatar
08HD
Great! I am getting the 08 EGC and plan to take off the tour pack and add a solo seat. Don't need the dealer to install this mod if I can do it my self to save on labor charge.
Old Apr 12, 2008 | 12:45 PM
Harleypingman's Avatar
Harleypingman
When you buy the mounting kit, also buy the Service Manual and a T27 Torx drive/socket if you don't already have one.
Unless there is some financial inducement to do otherwise, become familiar with the 20% off list price HD dealers like Zanotti's, Chicago HD, etc.--many here use them or others.
Old Apr 12, 2008 | 06:30 PM
gilbos440rt's Avatar
gilbos440rt
Love mine, being able to go from solo to full blown touring rig in the span of 20 minutes is GREAT! The factory bushing's do a good job till they wear out, seems that some last forever and others wear out pretty quickly, go figure There are solutions for the problem bushing's out there though!
Old Apr 12, 2008 | 07:47 PM
courterbag's Avatar
courterbag
ORIGINAL: Harleypingman
Carl nailed that one - good advice!
