sig test
Old Apr 13, 2008 | 10:44 PM
relli's Avatar
relli
Default sig test
test
Old Apr 13, 2008 | 10:48 PM
relli's Avatar
relli
Default RE: sig test
never mind. trying ta put a pic in my sig but even following directions i cant friggin do it. have ta get some 6 year old tomorrow ta show me i guess.
Old Apr 13, 2008 | 10:50 PM
PapaTravis's Avatar
PapaTravis
Looks like you are trying to get a pic from photobucket. Click where it says direct link on photobucket... it will then say 'copied'. Then go to 'my profile'. Go down to the sig area. Type, [IMG]paste pic[/IMG] . That should work for you. Make sure that the word image is lower case, and that you use the [ ] brackets, not the ( ) brackets...
Old Apr 13, 2008 | 10:52 PM
PapaTravis's Avatar
PapaTravis
To post a pic in the text window, you use the [img] [/img]... in the sig, you use [IMG][/IMG]
Old Apr 13, 2008 | 10:56 PM
PapaTravis's Avatar
PapaTravis
Also, you will need to size that pic down. Just copy this one, and save it to your computer. Then go to photobucket, and load it up... Should be fine. Don't give up just yet... once you know, it is very easy...
Old Apr 13, 2008 | 10:58 PM
PapaTravis's Avatar
PapaTravis
Looks like you are almost there. Just change the brackets...[ ]
Old Apr 13, 2008 | 11:08 PM
relli's Avatar
relli
well im doin something wrong. how did that pic get there. did i do that? i copied the snmaller pic and did as directed. arrrrrgh
Old Apr 13, 2008 | 11:16 PM
PapaTravis's Avatar
PapaTravis
right now in your sig it says,
[img]paste pic[/img]
it should read,
[IMG]the direct link you click on in photobucket[/IMG]
go to photobucket. Click under the pic where it says 'direct link'. When you do that, a little banner pops up and says 'copied'. then go back to 'my profile', on hdf. Between the [IMG] and the [/IMG] paste the link. make sure there is not a space between the two image brackets...
Old Apr 14, 2008 | 07:29 AM
relli's Avatar
relli
that did her guys. think the last mistake i was makin was leaving a space. thanks again
Old Apr 14, 2008 | 09:34 PM
PapaTravis's Avatar
PapaTravis
Glad ya got it. Like I said, once you know, it is easy...
pab
Aug 17, 2009 12:14 AM
HDUltraRider
Aug 10, 2008 10:43 PM
BigDeuceDoty
Welcome Area Only
15
Jul 30, 2008 11:41 PM
ultraclassicHD
May 27, 2008 11:23 PM
falsealarm
Apr 1, 2008 01:34 PM
