hog tunes
Old Apr 15, 2008 | 03:49 PM
bigirn's Avatar
bigirn
Default hog tunes
i instaled the hog tunes and ive noticed that when i kill the bike with the kill switch. then go to restart the bike i hear a pop in the speakers also it seems like the tack jumps as well. is this normal ?
Old Apr 15, 2008 | 04:21 PM
PEZ's Avatar
PEZ
Default RE: hog tunes
Hey there
Does not sound right to me
Based on your description I would check the following.......
In front of the tank on the brake side of thebike is a wire "strap" that holds wire harnesses and throttle and idle cables to the frame. Its a metal deal covered in a black vinyl material, and is held to the frame using a 5/16" head screw that will also accept a flat head screwdriver. When you remove the screw, you will see a black wire with a green tracer (2 of these wires on Road Glides) with a "ring" connector that grounds that wire to the frame. Please take the screw out and make sure the ground is OK. I suggest taking a nail file or emory board to clean the ring connector itself. This is where the radio and guages get their ground--so the radio popping, and tach jumping make this a suspect thats easily fixed
Let me know if you have other questions by email at info@hogtunes.com PEZ
Old Apr 15, 2008 | 04:32 PM
bigirn's Avatar
bigirn
thanks pex ill give it a shot.
Old Apr 15, 2008 | 04:48 PM
RD GLD's Avatar
RD GLD
Pez hooked you up. I was going to say ground issue but he was more specific.
Old Apr 15, 2008 | 05:41 PM
Scootr's Avatar
Scootr
PEZ is the man. I just ordered the rear speakers/pods/amp for my SG tourpak. Can't wait to get them!
dchappuies
Audio Systems
Dec 31, 2015 07:27 PM
uwiik
Audio Systems
11
Nov 11, 2013 02:40 AM
webbug
Dec 30, 2010 10:43 AM
VINNIE JAMES
Aug 28, 2010 12:21 AM
watercop
11
Jan 21, 2009 01:39 PM
