Quick PC3 0TP question
Old Apr 20, 2008 | 11:44 PM
2008FLHP's Avatar
2008FLHP
Default Quick PC3 0TP question
To get rid of the backfire/popping we're suppossed to bump up the 0 Trottle Position #'s up but, am I correct in assuming that there's no need to raise them until you get to 1250rpm?
Why add fuel when idling, right?
Old Apr 21, 2008 | 12:08 AM
DrBob81's Avatar
DrBob81
Default RE: Quick PC3 0TP question
I got a map from Dynajet, that only added fuel to the 0 setting above 2000 rpm (+30 from 0) and the 2 setting above 2500 rpm (+15 from 0) on an 07. It would still pop once as it went below 2000. Their customer service is pretty good. If you send them your map, they will generally modify it for free. My FM map on my 08 is unmodified, I kinda like the rumble from the glass packs.
Old Apr 21, 2008 | 06:56 AM
2008FLHP's Avatar
2008FLHP
Wow, 30 seems alot. How high up (RPMs) did those setting go?
Old Apr 21, 2008 | 07:02 AM
FLHT's Avatar
FLHT
30 does seem high to me. If I remember right I add 8 or 10 and I believe I took it down to 500 RPM. Can you tell I dont have my MAP in front of me
Old Apr 21, 2008 | 12:51 PM
2008FLHP's Avatar
2008FLHP
the most i've seen recommended is 20...but i have 2 questions...why would you want to increase fuel below 1000rpms, sitting at idle?...that doesn't make sense to me...and how high should you take it the rpms?, 5000rpms?...seems not needed
what i've done is 0 up to 1000rpms, and doubled from 1250 what was in the map originally (807-027)...it's better then it was, still popping a little bit, but still ower than 2%TP...next i'll try matching the #s from the 2%TP into the 0%TP, except for 500,750,1000rpms which i'm keeping 0
Old Apr 21, 2008 | 12:59 PM
risgdude's Avatar
risgdude
I was poping fro 1950 down to 1400 so I added 5 from 1500-2500 @0%it made a slight differance. Then I added 16 in the 2000+2250 @ 2% which made it better. but not perfect. T&E Still working on it.
Old Apr 21, 2008 | 01:33 PM
CREEPSHOW's Avatar
CREEPSHOW
I am guessing the fuelmixture at idle are lean from the factory. When changing pipes/aircleaner, this leans the mixture out more so your idle mixture is even leaner causing backfire. That is why mixture needs to increase at idle, if that makes sence. When you do a carb kitfuel mixture needs to increase at idle as well..
Old Apr 21, 2008 | 01:37 PM
2008FLHP's Avatar
2008FLHP
good point creep, i didn't think of that...and thats true about the carb, i did that on the last bike 97 Heritage...makes sense
Old Apr 21, 2008 | 02:06 PM
FLHT's Avatar
FLHT
Yes it is very lean at idle and even if you plug in some fuel in the grid below the normal idle speed it sure wont hurt anything.
Old Apr 21, 2008 | 02:19 PM
fastbagger's Avatar
fastbagger
'07 FLHX from 750-1250 I changed the 0's to 5's. Engine is a lot cooler @ idle now.
