Laser temperature setup on a bagger
Old Apr 21, 2008 | 09:33 PM
Dennis Murawski's Avatar
Dennis Murawski
Default Laser temperature setup on a bagger
I was at the local big box Chinese hardware joint and I noticed a very small laser temperature gun for under $20. The information on the package said it would read temperatures into the 400 degree Fahrenheit range with an accuracy of +/- 2 degrees.
I think it was small enough to allowmounting somewhere out of the wayand still have the laseraimed at a cylinder head. Is anyone familiar enough with de-soldering circuit boards to tell me ifit is possible toremove the on/off push button switch and the digital display screenfrom the unit unit and relocate them in the dash. If that's possible, I could get get an accurate digital head temperature reading at the push of a button.
I currently don't have the miniature de-soldering tools, but if it's not too outrageous, I'd give it a try. Any thoughts?
Old Apr 21, 2008 | 09:50 PM
Dalton's Avatar
Dalton
Default RE: Laser temperature setup on a bagger
Interesting concept, let me know what you figure out!
Old Apr 21, 2008 | 09:57 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Most, if not all of those IR devices read an area that is usually proportional to the distance from the spot measured.
ie; if your device is 5" from an object, it will measure the temperature of a 5"circle around the point of aim of the laser....10" = 10" circle
The laser is only an aiming device to give you an indication of where you are focusing your IR signal.
Old Apr 21, 2008 | 10:09 PM
iclick's Avatar
iclick
Hmm, I have one of those HF guns and actually thought about the same idea for a cheap head-temp gauge. It might just work, but will require someone to do the R&D. Problems I forsee is heat on the laser unit, as it will be very close to the engine at all times. You sound like a good candidate, so get cracking and keep us informed!
I had another idea, which was to find out if one of these head-temp senders that fit under the spark plug might just accidentally have the same values as the HD oil-temp gauge/sender. If so, you could wire it through a switch and toggle oil and head temperature. That would be way too easy, though, I'm sure. I've been meaning to call Dakota Digital about that, as they make such a sender for <$15.
Cruisineasy
Aug 11, 2019 08:31 AM
Deuce55
Jul 5, 2015 01:49 PM
Cruisineasy1
Sep 15, 2014 03:19 PM
JimA
May 4, 2013 02:39 PM
mattk22
Apr 16, 2011 10:28 AM
