bags rubbing?
Old Apr 22, 2008 | 05:08 PM
Ganzo68's Avatar
Ganzo68
Default bags rubbing?
wtf? my left bag on my 08 SG is rubbing on my side cover. I never moved them just took them off to install my mufflers. Should I move them back further or is the vibration from my exhaust making the bags move more and contact the side cover. Any help or suggestions? anybody ever have this problem? thanks Jason
Old Apr 22, 2008 | 05:57 PM
jack49's Avatar
jack49
Default RE: bags rubbing?
One of my RK hard bags was rubbing on the side cover,adjusted the
mounts and that took care of the problem. I don't think the dealer
checked bag to side cover clearance when setting up the bike.
Old Apr 22, 2008 | 06:28 PM
2008FLHP's Avatar
2008FLHP
go back to the dealer---it's "normal"
Old Apr 22, 2008 | 11:38 PM
RKKY's Avatar
RKKY
Checking saddlebag clearance is part of the PDI process. Sounds like your dealer missed it. If there is any damage to the paint, I would go to the dealer first and show him the problem/damage. Let him know you have not moved the mounts in anyway. Hopefully, they will take care of you (adjust the mounts and fix the paint). If there is no damage from rubbing then I would just fix it yourself. Just takes a 7/16" wrench and very little time.
Old Apr 22, 2008 | 11:42 PM
Mississippi Bagger's Avatar
Mississippi Bagger
It is probable that when you installed your mufflers the bar the bags sit on moved a bit, thus causing the bag to rub the side cover.
You can adjust the top mounts (where the pins go thru) and you'll be all set.
Old Apr 23, 2008 | 01:07 AM
rockhard69's Avatar
rockhard69
Dealer should cover it under warranty if you just got it. I found my right side that way at 1000 miles and the dealer replaced the saddle bag and side cover. Said they should of found it when they assembled the bike.
Old Apr 23, 2008 | 05:14 AM
rocknrod's Avatar
rocknrod
ORIGINAL: Ganzo68
Whenever you remove the bags, make sure they are back far enough not to rub when you re-attach them.
The upper mounting hardware that they attach to can be adjusted.
Make sure there is clearance between the front of the bag and the side cover.
If the quick release pins dont line up, adjust the mounting hardware.
Warranty Item?
I guess you can work it that way. Doubtful the dealer will buy it (I wouldnt). But hey, give it a try.
Old Apr 23, 2008 | 06:25 AM
Xtreme's Avatar
Xtreme
good luck gettin the dealer to warrenty it, just loosen the mounts and slide them back a bit.
Old Apr 23, 2008 | 06:28 AM
wideopen1967's Avatar
wideopen1967
Gold bond usaully helps when my bags have been rubbing............
Peppa1's Avatar
Peppa1
You can also add some washers behind the mounts and move the bags out just a little bit too. I did that on mine to help prevent it from rubbing.
