Thanks, if it's not too much trouble, would you have the part numbers for the two outer cam bearings and the oil pump to Cam support o-ring #
Thanks
Rev
8983 BEARING ASSEMBLY, w/ bearing assembly, inner race, washer & O ring
8990A BALL BEARING
11286 O-RING (?This is part of the Oil Pump ***'y)
11157 O-RING (?This is on the backside of the OP ***'y)
