Broken Part?
Old Apr 26, 2008 | 09:55 PM
Biker_RN48's Avatar
Biker_RN48
Default Broken Part?
In a nutshell, I was installing something on my 07 RK today. I loosened up the gas tank, so I could run a couple wires under the tank through the plastic harness holder.
I heard a snap, and saw gas pouring out on the floor. There is a 90 degree under the tank, that connects to a hose. Then the hose connects to s nipple (broken off in the hose) and a plastic piece that connects to as metal tube on the engine.
ANybody know what this piece is called so I can get another? I can't find an actual name or part number online or in the service manual?
Old Apr 26, 2008 | 11:55 PM
izzi's Avatar
izzi
Default RE: Broken Part?
pm DAWG.
Old Apr 27, 2008 | 12:01 AM
biz44's Avatar
biz44
If you can snap a clear picture, I could try to look it up in my 08 touring service manual, and see if I can get you the PN for it. The only problem is that with the change from 5 gallon to 6 gallon for the 08 MY there may be differences to the plumbing under the tank.
Old Apr 27, 2008 | 12:29 AM
Biker_RN48's Avatar
Biker_RN48
Ok I tried again, finlally after about 30 pics...........
The backround is a picture of this exact thing, but no name or number.
Old Apr 27, 2008 | 06:05 AM
Jinks's Avatar
Jinks
Quick release/Quick disconnect. There are several manufacturers that make 'em out of metal. Those don't break every time you handle 'em.
Old Apr 27, 2008 | 06:18 AM
airforcedad's Avatar
airforcedad
6th Gear
I did the same thing last week, Matched the fitting up at NAPA. the release is a different style, but it works fine.300 miles and no problems. I also replaced the spring style hose clamps with worm gear fuel injection clamps.Hope this helps.
Old Apr 27, 2008 | 07:20 AM
kurtlange's Avatar
kurtlange
ORIGINAL: Biker_RN48
this is what i replaced the line on mine w/-- http://*******.com/6c95lr
yes it for a dyna but it fits the touring bikes also.
Old Apr 27, 2008 | 08:50 AM
Harleypingman's Avatar
Harleypingman
The picture you show from the SM is the attachment of the "fuel supply line" to the induction module's fuel supply tube. My '04 parts book doesn't give a seperate PN foryour broken fitting, just the "fuel line assembly," PN 61340-02A, to which it is attached. You have an '07 so the parts and PN's may be different, but the pics from your SM are the same as in my '04 SM.
PM Dawg, or perhaps someone with the '07 parts book will chime in.
Old Apr 27, 2008 | 09:07 AM
shadowchaser's Avatar
shadowchaser
My 08 parts book shows #62905-08 FUEL LINE, tank to intake. Hope this helps, I know the year is different.
DK Custom - ST
Vendor For Sale Classifieds
Nov 26, 2018 12:34 PM
kona74
EVO
Dec 14, 2014 10:29 AM
SCHOONER
Feb 9, 2012 05:47 AM
P'colaHarley-17RGS
Jan 11, 2009 01:45 PM
jd_underdog
Feb 13, 2006 05:11 PM
