2 Into 1 & Lugging
Old Apr 28, 2008 | 07:32 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: 2 Into 1 & Lugging
The older engines were designed for the lower rpm - this one ain't. You may not be hearing problems, but ah've got a 96, an' I DO hear a major difference in the engine under 1500 rpm at load - so ah'm not shore iffen mebbe the old pan took yer eardrums out.
Bottom line - it's yer bike, do as ya wish. Ah'm jest tryin' ta let ya know that yer not doin' ANY part of yer drive train any favors.
Old Apr 28, 2008 | 07:44 PM
notlost_nc's Avatar
notlost_nc
Report back after riding this way for a year.
61panhead's Avatar
61panhead
I have 2 into 1 (D&D Fat Cats) and I agree with TexasRedneck.
If you're running 50 mph in 6th gear and you are pulling at all, you are lugging your engine. I suppose if you're coasting downhill you are OK.
6th gear is not happy until you get above 65mph.
Old Apr 28, 2008 | 07:48 PM
maineultraclassic's Avatar
maineultraclassic
I have more power with my 95" then your 96" motor ...........and I don't let my motor get below 2000 rpms at all, 2500 and above is even better.
The reason you are not feeling the lugging is because of the IDS system. Believe it or not, you're lugging your motor and you're doing damage if you continue to do it.
Steve
Old Apr 28, 2008 | 07:49 PM
mariner227's Avatar
mariner227
ORIGINAL: TN Houndog
Mariner, use your tach!!!! I have no doubt your engine is "happier" with your new combination but you'll have fewer problems and it'll most likely last longer if you keep it above 2,000 RPM under load. My riding bud has a Streetglide with a 255 SE cam, SE heavy breather, and a V&H propipe. It WILL definately pull at lower RPMs than I suggested without shuddering, but it is putting MUCH greater torsional load on the crank. You may get away with putting the extra load on the crank for the life of the bike, but why take the chance?
I agree. I'm just amazed at the difference now.
Old Apr 28, 2008 | 07:55 PM
byersmtrco's Avatar
byersmtrco
Lugging . . . Lugging . . . Lugging . . . Did I say lugging?
Don't even THINK about 6th gear until your going MINIMUM 65 mph . . . Then don't shift until 70.
Old Apr 28, 2008 | 09:08 PM
Beemervet's Avatar
Beemervet
ORIGINAL: mariner227
Reread the post!!! I asked for opinions from people who actually have 2 into 1 exhausts on their touring bikes.
I think I might have 2/1 pipes.
Old Apr 28, 2008 | 09:21 PM
FastUltra's Avatar
FastUltra
ORIGINAL: maineultraclassic
Steve
I'm with Steve on this as my 95 has more and I DO NOT lug it!! Be careful with your motor!
Old Apr 28, 2008 | 09:23 PM
FastUltra's Avatar
FastUltra
ORIGINAL: Beemervet
yeah but you have it hidden behind all that header wrap!!
Old Apr 28, 2008 | 09:32 PM
04RoadKing's Avatar
04RoadKing
I don't have a 6th gear but mine will do 5th gear roll-ons alot quicker then it did with the Rineharts.
