No spark problem
Old Apr 28, 2008 | 08:33 PM
jedwards48's Avatar
jedwards48
Stage II
Default No spark problem
Before riding my remote charging hot wire shorted and burnt the insulation from the wire. Cleaned it up and started to ride. Didn't make it a block before it died, dead. Starter spins normal. Put new plugs in, checked the plug wire resistence and was ok. Checked the coil resistence. Primary's should be between .5 - .7 and measured 1.2 and .7. Secondary's should be 5.5 - 5.7 and measured 5.6 and 5.7. Tachjumpswhenspinning the starter so probably not the CPS. I'm thinking a new coil because of the 1.2 reading. Think I'mon track or something else??
Old Apr 28, 2008 | 08:47 PM
OD_Cleaver's Avatar
OD_Cleaver
Default RE: No spark problem
Let me be the first to respond.
I think that you need to go basic before you put on any new parts. First check for spark using one of your old spark plugs grounded to the engine. You said that you had no spark, but did not say how you confirmed it.
I don't see how a shorted charger can destroy a coil. There are a lot more sensitive parts on the bike.
If you learn that you have spark, then check for fuel delivery.
If I am off base, you have my apology.
OD
Old Apr 29, 2008 | 05:27 AM
Kenr427's Avatar
Kenr427
start by checking all your grounds, A bad ground can do the same thing
Chango1079
Aug 16, 2019 11:37 PM
yellowpearlfb
Electrical/Lighting/Alarm
Oct 11, 2015 03:43 AM
Iron Man73
Ironhead
14
Sep 30, 2013 08:44 PM
EvilWayz
Ironhead
13
Sep 7, 2010 05:40 PM
jedwards48
Apr 29, 2008 07:57 AM
