Radio Static
Old Feb 18, 2006 | 12:01 PM
dja1340's Avatar
dja1340
Default Radio Static
Just got the stock radio on my 86 FXRD up and running. Radio plays alright except for some momentary stactic when I use the rear brake. It appears to be caused by activation of the brake light. Does not do it when the front brake only is used. Any clues?
DJA
Old Feb 20, 2006 | 01:21 PM
pilot1996's Avatar
pilot1996
Default RE: Radio Static
Check the ground....check the ground on the brake, check the antenna make sure it's not worn through. Somewhere you have a ground problem check all the wires, look for any signs of wear. Let us know what you find.
Mac
Old Feb 21, 2006 | 01:03 AM
SamStone's Avatar
SamStone
Louder pipes should cure the problem
silvertex1
Electrical/Lighting/Alarm
Aug 12, 2014 01:17 PM
xd.404life
Wheels/Tires
Feb 8, 2011 05:41 PM
quint8
Mar 7, 2010 12:12 AM
swojo
Mar 26, 2008 08:46 PM
dja1340
Feb 25, 2006 11:18 AM
