well it didnt take long for me to loose a security fob...i have a spare and need to order a new one to replace the one i lost today,i tried reading owners manual to see how to overide the system using the turn signal switches....it says there is a 5 didgit code inside of fob????i dont see it.. there is a small plastic tag on the fob ring but thats only 4 didgit i think it could be for the barrel key...i fond a white sticker inside the fob with 3 lines of numbers and letters any ideas where to find my pin number???? thanks for any help
i read the owners manual, and saw the part about changing the pin number ....i thought that one is already installed...or do you make-up your own first?
When bikes are PDI'd at the dealer they are set up with a PIN. Different dealers use different numbers. Go to your dealer and have them hook it up to Digital Tech, takes about 2 minutes to see the old PIN and put in a new one of your choice. If you have a good dealer they shouldnt charge you!
The sticker inside the FOB it the assignment # for the FOB itself!
thanks,i ended up setting my own pin number,and ordered a new key and fob,too bad you can only have 2 fobs assigned to a bike at a time.i can see i am going to need a box full of these things
