Ride-Str8 vs TWR
I think the point you are missing is that HD spends a lot of $$ for research and developement. They engineered a cast iron bracket on an intregal part of the bike. That bracketattaches the swingarm to the frame.This may be just me but I feel more comfortable with a stonger piece of hardware at that point. I have more trust in HD than in a piece of aluminum.That's just me. To each his own.
This thread was simply meant to be informative, nothing else.
I believe that statement was in reference to the maker of the part having industrial liability insurance. As in, can the company afford to re-imburse you if their product fails and your bike is damaged, or you get hurt as a result.
Well, maybe one day you'll find YOURSELF on the other side of that argument so we can find out what you think when the shoe is on the other foot. As in, when your out of work cause someone will do your job for a buck an hour less, or when the product YOU spend YOUR life savings developing, suddenly stops selling because of cheaper knockoffs.
Lemme guess, you think Walmart is the greatest thing ever?
Like a monopoly? I guess you like paying 4 dollars for gas???
lp
But also welding to a cast part is not always the best practice... So to back the claim that the weld is stronger they do perform an xray to find any voids that could possibly be within the welded area from the cast process? (this could be a weak point) Then after welding do they perform a die penetrant test to verify there are no surfacecracks? What is the minimum allowable crack if there are any?
The 6061-t6 material has a yield strength of 40ksi... yield is the amount of stress a part can take to deform and recover back to its original shape. 1018 can have a minimum of 35ksi.... The tensile strength is the amount of pressure a part can take before it shears.... the 1018 is 60 ksi and the t6 is 45 ksi..... Now if the TWR was thinner i would be a little concerned but it is not..... 45,000 pounds per square inch..... That's a crap load of force. Yeah 60,000 is more but is it needed?
Personally I would prefer using a billet piece over a weldment as a welded joint does induce stresses..... So I'm sure the Ridstr8 stress relieves there parts to reduce the induced stresses from welding? I'm sure the weldment has the same tight tolerances as a machined billet piece?
Atleast knowing the TWR is machined from billet I can only assume the tolerances are tighter then a weldment.
The biggest point in my decision was cost.... and convenience..... With todays technology I have to send a check or money order..... come on.... what a pain in the ****...
Both productsshould work as specified..... Are the products similar... sure.... But like has been said... a small change in the design is not a patent infringment... If the statement was true that cause of a US patent a product from Canada can not be sold in the US.... China would be in some serious trouble... How many products have been reversed engineered in China and then sold in the US?
Like has been said I am all for competition.....
Just my .02
Oh by the way we just purchased our first TWR and if it works we will stock some and TWR does have different model for the early versus the late model baggers. After we try it then we will make an informed decision, not an assumption.
But also welding to a cast part is not always the best practice... So to back the claim that the weld is stronger they do perform an xray to find any voids that could possibly be within the welded area from the cast process? (this could be a weak point) Then after welding do they perform a die penetrant test to verify there are no surface cracks? What is the minimum allowable crack if there are any?
Both products should work as specified..... Are the products similar... sure.... But like has been said... a small change in the design is not a patent infringment... If the statement was true that cause of a US patent a product from Canada can not be sold in the US.... China would be in some serious trouble... How many products have been reversed engineered in China and then sold in the US?
At one time, there was a "chopper company" which suffered a streak of bad luck due to welds breaking. So, are we to believe that welds are in fact stronger than a solid piece of metal? Well by golly, whaddayaknow, I don't own one of "those" bikes but it sure looks like the frame on my OEM HD frames are welded! Does this then mean that my OEM frame is going to fall apart just like the frames from "the other company"? Maybe, maybe not.
Is this a case of the fox with sour grapes? Perhaps. TWR made a very sensible move to offer a group discount to us bagger folk, something which RideStr8 did not. Why hasn't RideStr8 done the same? Would the RideStr8 crowd be in such a mood had they had a group buy that was as successful as TWR's? I doubt it.
Are both TWR and RideStr8 gouging us? Maybe, maybe not. RideSt8 has demonstrated that the HD part they use costs around $55 onto which $330 is added for welding, nuts 'n bolts and a reach around. Is TWR doing the same? Maybe, maybe not.
Who really cares! Pick one, install it and ride the shyte out of your bike rather than playing keyboard warrior!
Everybody is yapping about the plate on the swingarm. But, whether this thing works or not is totally dependent on 3 1/4 inch bolts that are secured by being threaded into a cast housing.
I dislike anything that is installed directly (as an add-on) between the frame and the engine, without any dampening devices in between.
I am wondering about what type of side thrust, (shearing force) is being applied to the 3, 1/4" bolts in the transmission. And, how much vibration is being transferred to these bolts and their threads in the transmission case.
This may or may not be a problem, and quite possibly might have already been addressedby someone with more knowledge than me.
I am just leary of attaching anything to case bolts, which in turn could be stripped or broken and necessitate major repairs to those cases.
That's our fault.
Just like paying 40K for a Harley when it does not cost anywhere near that to produce one.
Mike
