Battery re-connect
Old May 8, 2008 | 09:52 AM
charlesk's Avatar
charlesk
Default Battery re-connect
Ok, this is pretty much a newbie question. I am installing a radio amp on my ultra. Before I started the work, I disconnected the (-) negative wire to the battery and then the (+) positive. I am now to the point where I need to reconnect.
According to the manual, you are to connect the (+) first then the (-) as a spark could be damaging. I've connected the (+) but when I go to connect the (-) I get a small spark and I notice that the speed and tach jump slightly.
Does this sound ok or do I have a problem? I sure do not remember a spark when I disconnected the (-) at the beginning of work.
Old May 8, 2008 | 09:55 AM
Gart's Avatar
Gart
Default RE: Battery re-connect
Depending on what year/make you have, that is normal. Computer, radio, etc are all drawing a little current.
Old May 8, 2008 | 10:00 AM
charlesk's Avatar
charlesk
Thanks, it's an 07. Guess I am just being a little cautious here.
Chuck
Old May 8, 2008 | 10:58 AM
AlleyKatt's Avatar
AlleyKatt
You could remove the main fuse, hook up the battery, then reinstall the fuse. Whenever you hook up a battery and there is a draw, you will see a small bit of spark.
Old May 8, 2008 | 06:47 PM
TexasRedneck's Avatar
TexasRedneck
Actually, if you could see the contact points of the fuse, you'd see the spark there as well. It's perfectly normal, because ya have a constant (albeit small) drain on the battery due to the electronics.
Old May 8, 2008 | 11:10 PM
acftdr's Avatar
acftdr
On all 12 volt negative grounded vehicles(cars, bikes, airplanes) the reason why you disconnect the negative first and connect last is because if you accidently hit the frame or anything grounded with your wrench you won't have a dead short across the battery. There's no potential (voltage) from the negative post to ground when the battry is hooked up. If you disconnected the positive first and banged the wrench against "ground" you'll have a nice spark show and a hot wrench to boot. If you're lucky the wrench won't arc weld itself to the frame. Ask me how I know. Once the negative is disconnected, the frame (ground) is no longer the other half of the circuit. You can then short the positive to ground without worry 'cause the negative side isn't hooked up.
The small spark you get when hooking up the cable is like the other guys said, it's just a small draw due to all the electonic crap now days.
Old May 9, 2008 | 07:19 AM
Jeff Dodson's Avatar
Jeff Dodson
ORIGINAL: acftdr
He is exactly correct, but the order you discoonnect and reconnect is because the the spark that happens when hooking up the + last could cause a spike and CAN blow the voltage regulator, as I said "CAN".
Old May 9, 2008 | 07:20 AM
mllkn6's Avatar
mllkn6
+1 with redneck, if you have a clock you'll probably need to reset it. With my Thundermax if I disconnect the battery or pull the main fuse I have to reset the Thundermax as well.
J McBri
May 13, 2019 09:13 AM
zyban
Electrical/Lighting/Alarm
Jan 19, 2017 04:19 PM
kdodd
Jun 18, 2013 09:50 PM
fatboy2176
Sep 6, 2011 07:29 PM
BB4xl
EVO
Aug 29, 2010 03:15 PM
