Batwing Wobble?????
Old May 13, 2008 | 03:56 PM
IRideMineEverywhere's Avatar
IRideMineEverywhere
Default RE: Batwing Wobble?????
Pull the front of the fairing off and check the mounting bracket out as well. There seems to be a LOT of these being broken, including mine...
Old Jul 21, 2011 | 05:19 PM
cpooser1's Avatar
cpooser1
3rd Gear
I have had many wobble issues and have tried many cures. What you will find out is once you stabilize the Engine/frame you may still have problems coming from the front end. I installed Ricor Intiminators in the front shocks and they really helped. I still have an issue and am considering Custom Cycle Engineerings Triple Tree top bracket kit. One thing I have discovered is the batwing vents when open make a big difference during high winds and cornering wind shear causing a slow wobble. Good luck with yours!!
Chris
Old Jul 21, 2011 | 05:23 PM
klaybus's Avatar
klaybus
While I don't ride a AG, I've never had the death wobble I've heard others talk about except in high wind. Then it's just a slight wobble.
Old Jul 21, 2011 | 05:28 PM
Navyrep1's Avatar
Navyrep1
If you've got some decent miles on the bike, almost without question it'll end up being the steering head bearings out of adjustment. Yeah, could be this or could be that...check the obvious stuff (tire, weight distro, road surface, fairing loose, etc)....but the wobble damn near ALWAYS ends up being caused by head bearings or other loose front end chassis component. Check it yourself or get it checked soon.
Old Jul 21, 2011 | 05:35 PM
SH_01FXDWG's Avatar
SH_01FXDWG
Somebody told me if I had some loose spokes or rear tire pressure was low it could cause that. Sure enough I had some loose spokes so I tightened them up and raised my rear tire pressure to 42 lbs. While not perfect, but way better.
Old Jul 21, 2011 | 05:45 PM
qtrracer's Avatar
qtrracer
Loose nut behind the bars is usually the cause.
Old Jul 21, 2011 | 06:01 PM
dirtracin23's Avatar
dirtracin23
That shouldn't cause a wobble at 65mph.
Front tire and then steering head bearings is where I would direct my attention first.
Old Jul 21, 2011 | 06:13 PM
cooper57M's Avatar
cooper57M
The road / highway can cause a wobble especially if you got a highway where there is a continual tar snake, it will cause a weave/wobble. I asked my friend who at times was riding in the same patch of road in front of me who was also riding a bagger experienced the same.
Old Jul 21, 2011 | 06:14 PM
Rickr01's Avatar
Rickr01
Nope, no wobble at all, but have not had her much over 100 Mph while passing. And Vermont has some serious interstate cross winds. I'd check for stearing head adjustment, cupped tire, loose front wheel bearings.
Old Jul 22, 2011 | 11:20 AM
Navyrep1's Avatar
Navyrep1
Obviously the Good Idea Fairy is running around like a total nutcase.....you guys are killin' me!
