SPARK PLUGS
Old May 13, 2008 | 08:03 PM
langlois1's Avatar
langlois1
Default SPARK PLUGS
I KNOW SOMEONE WILL BE ABLE TO ANSWER THIS QUESTION. WHICH IS WHEN CHANGEING SPARK PLUGS DO YOU HAVE TO USE HARLEY BRAND?
Old May 13, 2008 | 08:05 PM
Bill03E's Avatar
Bill03E
Default RE: SPARK PLUGS
NGK, ACCELL ,DENSO ,and Autolite are good ones.
Old May 13, 2008 | 08:08 PM
SteveO's Avatar
SteveO
I have tried them all and found the stock HD plug works best, and has the smoothest idle.
Steve
Old May 14, 2008 | 05:41 PM
fritz982's Avatar
fritz982
personally Harley-Davidson sparkplugs worked fine for the most part, for a stock engine. But, if that's not the case you need to expand parameters! I personally now use Autolite, after recommendations by my tuner. I was having some difficulties with stock plugs, and moderate RPM roll on's. So far I've seem to cure the problem with the change. I find them to burn exceptionally clean, virtually no carbon buildup on cold engine starts like I did with the Harley-Davidson plugs. Also after a good days hard ride I find porcelains, to be exceptionally clean and residue free.
Old May 14, 2008 | 05:43 PM
gordon188's Avatar
gordon188
Stock Harley plugs here, no complaints and great idle.
Old May 14, 2008 | 05:49 PM
dawg's Avatar
dawg
Autolite 4164's
Old May 14, 2008 | 05:59 PM
binkman78's Avatar
binkman78
ORIGINAL: SteveO
Steve
+1 every 10K
Old May 14, 2008 | 07:12 PM
Lincoln33's Avatar
Lincoln33
I just changed mine and used the Harley plugs. I'll spend the $6 dollars at the local dealerfor the peace of mind. I'm not sayingyou have to use the Harley plugs but the service manual says "no substitutes". GoodLuck
Old May 14, 2008 | 10:30 PM
TXCHOP's Avatar
TXCHOP
Stock HD or NGK. Mostly NGK now as i like how i can read the a bit better....They been great on stock bikes and some of the larger builds i have been doing.
Old May 14, 2008 | 10:41 PM
hogdoc's Avatar
hogdoc
ORIGINAL: SteveO
Steve
At my last shop we used stock 6R12's on all kinds of motor combos up to mid 130 HP. Anything that had a lot of compression got 10R12 V-Rod plugs including a 147 HP 131" build. Seen EVERY other brand of plug cause problems
