Has anyone placed the SE 6 Speed Tranny on an Ultra?
Yes, but it is still winter here and I have not been able to ride since it was done. [:@]
Had the gear kit done. If I had it to do over I think I would do the whole trans swap so I could sell the 5 speed.
The gear kit requires a hole drilled in the top of the trans case and a sensor moved. Rather than plug the existing hole the kit contains a small plate and a gasket. I was warned that everyone the local dealer has done using this system has leaked around the plate. The MOCO now sells a part to plug the old hole that your local dealer will be more than happy to sell you.
I put it in my 03 FLHRCI. I love it. Lowers rpm significantly. Curise at 80-85 all day and still get great gas mileage. Transmission is normal up to the 6th and it is .89 to 1 overdrive. Worth ever penny to me. I have not had any leaks yet?
