leveling bike to check fludis
Old May 14, 2008 | 07:27 PM
leon anthony's Avatar
leon anthony
Default RE: leveling bike to check fludis
the 06 and down check the transmission stright up the 07 and 08 on the jiffy stand
Leon Anthony
Old May 14, 2008 | 08:03 PM
themensh's Avatar
themensh
If you must check your oil when LEVEL.......do it once.
Then, let the bike set on the jiffy. Take out the oil stick and mark it again
at the oil level 'when on the jiffy'.\
As long as you know where the level should be, it doesn't matter
if the bike is level or not, just some years harley decided to make us
hold the bike up-right.
Chuck
Old May 14, 2008 | 08:55 PM
PiedPiper's Avatar
PiedPiper
seems to me, you need a shop manual for your model and year bike. or, you can try one of the 23 options listed above.
Old May 18, 2008 | 12:57 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Hugh Jass
Correct, the bike has to be on the stand to correctly check fluids,
Wrong, to check tranny and primary oil
bike has to be level.
Old May 18, 2008 | 02:12 AM
badinfluence63's Avatar
badinfluence63
The manual to your bike will tell you whether to check it on the jiffy or straight up. If straight the suggested wood chip works well.
Old May 18, 2008 | 05:57 AM
Jrsess's Avatar
Jrsess
On the 2008 SG the bike is on the jiffy stand for engine and transmission check. Level for primary only!
Old May 18, 2008 | 06:00 AM
alqaadir's Avatar
alqaadir
bad move you should check fluid levels on the jiffy stand
Old May 18, 2008 | 09:59 AM
smitty901's Avatar
smitty901
Engine oil is checked on the jiffy. for chnages this is one way
[IMG]local://upfiles/52318/FEEC0097F134436DB3AED9822C197396.jpg[/IMG]
Old May 19, 2008 | 11:02 AM
XTrooper3936's Avatar
XTrooper3936
Before I installed the Wheeldock center stand on my bike, I always used a length of 2x4 under my jiffy stand. This works just fine.
Old May 19, 2008 | 12:35 PM
JoeSwiatek's Avatar
JoeSwiatek
If the bike has a pivoting dipstick (it swivels in the cap) then it gets checked on the jiffy stand.
jcanrun
Feb 9, 2022 04:40 PM
just plain john
Mar 24, 2014 06:53 AM
jgbrown54
Sep 4, 2013 05:06 AM
jmn1960
Aug 15, 2012 05:48 PM
dfa
Apr 10, 2008 10:01 PM
