my newly painted inner is on
#32
RE: my newly painted inner is on
ORIGINAL: cfmii11Hey Ron,
The fairing looks great, I do have a question though.
How effective are the Polk tweeters, do they really make a difference?
Do they require an amp to power up or are they plug & play?
Fill me in on the install.TIA,Charlie
The tweeters make a huge difference. I wear ear plugs and they cut out a ton of high end sound which is where all the clarity is. The tweeters really add that sparkle back to the tunes. There's a diagram on the Hogtunes web site for wiring them in - http://www.hogtunes.com
Basically you just piggy back right off the main speaker connections. The Polks have a crossover so I soldered the wires going to the crossover directly to the tabs on the fairing speakers. The stock radio powers them just fine - no amp required. I drilled a couple holes in the web of the inner fairing and zip tied the crossovers and wiring there on each side.
Hope that helps....
#33
Hey Ron. Looking at the last pic you posted gave me an idea. Have you thought about painting the inner part of your lower fairings? I think it would look great. I've never seen it done before.
Also, is that a cymbal you have on your air cleaner cover? I'd like to see a better pic of that.
Zach
Zach
#34
#36
ORIGINAL: Biggzed
Zach
Zach
I though about that but the material on the lowers is a soft almost rubbery kind of stuff and I don't think it would paint well.
Yes - it's an old 14" Zildjian of mine that I cut down and shaped to fit the air cleaner. Here's a better photo
[IMG]local://upfiles/9233/9480E124A4784F44A1B502FFA8CEB2AE.jpg[/IMG]
#37
ORIGINAL: RonH
Hi Zach
ORIGINAL: Biggzed
Zach
Zach
