travelling oil
Old May 15, 2008 | 12:47 PM
jakedog's Avatar
jakedog
Default RE: travelling oil
ORIGINAL: BadBobOk
ORIGINAL: jakedog
ORIGINAL: Chicago Spike
AMSOIL MCV will last your entire trip just fine, unless you plan on going longer than 15,000 miles
Or unless you have a unforeseen problem where you need to add oil.........
JD
My Amsoil dealer said to add any good dino 20/50 if you're in a bind but do not add another brand of synthetic.
I guess you could do that but why not simply use an oil that is available everywhere?....
JD
Old May 15, 2008 | 12:59 PM
fxdwg_rugby's Avatar
fxdwg_rugby
For any overnight trips, you should pack a quart anyway... If you are burning more then that, you have bigger problems...
Old May 15, 2008 | 01:05 PM
old95's Avatar
old95
one of the 4 of us just takes an extra qt. problem solved.
Old May 15, 2008 | 01:08 PM
jakedog's Avatar
jakedog
ORIGINAL: fxdwg_rugby
It is not a matter of burning; what about I laid it down and it simpley leaked out and now I need to replace it and I need 2 QTS? Where are you going to go? Walmart or ?...........
JD
Old May 15, 2008 | 01:26 PM
BadBobOk's Avatar
BadBobOk
ORIGINAL: jakedog
ORIGINAL: BadBobOk
ORIGINAL: jakedog
JD
JD
Because I prefer Amsoil.
Old May 15, 2008 | 01:33 PM
jakedog's Avatar
jakedog
ORIGINAL: BadBobOk
ORIGINAL: jakedog
ORIGINAL: BadBobOk
ORIGINAL: jakedog
JD
JD
And thats fine, I was only pointing out you can escape this problem by using a more available oil...........
JD
Old May 15, 2008 | 01:47 PM
CTB's Avatar
CTB
I run Amsoil - got a couple of cases of it in the garage. Though for my trip in June I'll likely change to Syn 3 so I can pick up a quart anywhere if I need to add. When I get back I'll change back to Amsoil.
Old May 15, 2008 | 06:19 PM
iclick's Avatar
iclick
Mobile 1 would win the nationwide-accessibility contest hands down. You can find the 15w50 in most Wal-Marts and auto-parts stores, the 20w50 VT probably not quite so available. Royal Purple is sold at Pep Boys and Napa in this area, and if this holds true nationwide would make it quite accessible, too.
Whatever you use regularly, you could use almost any of the main players in the synthetic oil business in a pinch. You could mix Mobil 1 with Redline or anything else without any problems.
Old May 16, 2008 | 01:46 AM
BRO's Avatar
BRO
If you are runing fully syn and you cannot find your 1st choice of fully syn oil while on a trip and you really need oil. Then buy any fully syn oil that is available, it will not hurt the bike. When you get home and/or it is time for the next oil change put in your choice again. Because we are creatures of habit; most of the time when your in a situation having to use oil that is not your first choiceit's the operator that gets nervous, the bike is just fine.
Just don't mix oils, however, some oil is better than no oil; so it can be situational. There are lots of places to buy oil of all types all over the US, so just go andenjoy thetrip.
Old May 16, 2008 | 02:08 AM
SeaHag's Avatar
SeaHag
ORIGINAL: iclick
Just another reason my choice is Mobil 1 15W-50....Available EVERYWHERE.
whyrzwaldo
Dec 7, 2016 11:31 PM
ShortsNSandals
Jan 5, 2013 09:46 PM
DarthMaul
Oil Archive (no new posts)
Sep 4, 2011 07:50 AM
thebear81
May 3, 2011 08:32 PM
sledgeman44
Aug 3, 2010 08:12 PM
