FUELPAK HELP
Old May 20, 2008 | 07:24 AM
katobird's Avatar
katobird
Default FUELPAK HELP
my question:
FINAL INSTALL WILL BE V&H TRUE DUALS HEADER PIPES AND STOCK CORED MUFFLER WITH EITHER K&N 1499 OR RK 3909 AIR FILTER.
PREFERRED / RECOMMENED MAP?
Vance and Hines response:
Unfortunately we do not offer any maps for the stock exhaust, even if it has been altered.
Derek Hewitt
Technical Support
Vance and Hines
13861 Rosecrans Ave.
Santa Fe Springs, CA 90670
www.vanceandhines.com
Anyone have a map or setup suggestion
07 electra glide classic
Old May 20, 2008 | 10:14 AM
rebeltruce's Avatar
rebeltruce
Default RE: FUELPAK HELP
The Fuel pak is a tricky beast, V&H isn't really forthcoming with exactly what any of the'mode' settingscontrol, so coming up with a 'custom' set-up will be extremely difficult.
Try the standard 07 Touring settings with the High Flow A/F settings and V&H exhaustquiet baffles.....bike may run perfectly.......
http://www.fuelpakfi.com/harley1.html
Old May 20, 2008 | 10:32 AM
rjgraham's Avatar
rjgraham
ORIGINAL: rebeltruce
Worth a shot.....
Old May 21, 2008 | 09:28 AM
katobird's Avatar
katobird
Update, will be RK-3909. I have found a map (FP-0538) looks close. Still looking for the expertson fuelpaks. Any help would be great.
Also the IDS.... sounds like Zanotti's is the place
Old May 21, 2008 | 09:40 AM
swomack's Avatar
swomack
Just run the map for true duals with basic slip-ons.
Old May 21, 2008 | 09:56 AM
dirtdobber's Avatar
dirtdobber
If that doesn't do it try this
# FP-0863
This is for V&H true duals, high flow ac, and se 64895-07 mufflers.
The 07A mufflers are less restricted than the stock but more restricted than most -including the V&H slip on's.
I can tell you the V&H slip on settings may work but the performance and mpg will suck. If you are trying to keep it rather quiet think about the 07A's but if you want to stay close to the stock mufflers try 64895-07; some what more restricted than the 07A
Hope you get it going
jim
Old May 21, 2008 | 11:40 AM
harleyflo's Avatar
harleyflo
What to do with a fp.start by not buying one!
Old May 21, 2008 | 11:45 AM
Odd Job's Avatar
Odd Job
Something else you might want to look at if you get frustrated with the Fuel Pak
http://nightrider.com/parts/
O2 IED 14.2:1 AFR O2 Sensor Inline Enhancement Device
Old May 31, 2008 | 10:09 AM
katobird's Avatar
katobird
RK 3909 AND FUEL PAK INSTALLED WITH BASIC MAP FP-0538.
RUNS GOOD
THIS FOR ANYONE ELSE THAT HAS THE STOCK MUFFLERS THAT HAVE BEEN POUCHED OUT.
BUT STILL WAITING THE DUALS TO ARRIVE
Nick412
Jan 12, 2015 06:07 PM
hythomasf
Jun 4, 2010 12:02 PM
Motosportman
Aug 25, 2008 07:02 PM
joeld0803
Jul 3, 2007 02:59 PM
gunrunner
Sep 1, 2006 08:23 PM
