Unused connector/Tour Pak
Old May 20, 2008 | 08:17 AM
Gregte's Avatar
Gregte
Default Unused connector/Tour Pak
I assume the unused small square connector lying in my tourpak is for the "optional" side marker lights that "used " to be standard on the Electra Glide Classic??? If that is the case I then would assume the 3 wires it is made up of are Ground/Brake/Tail ??? (At least that appears to be the case when looking at my service manual....but you never know)Therefore I would imagine that I could splice into these wires as needed or is the corresponding maleconnector available separately?? And finally can this connector be used for the tour pak spoiler brake/tail???
Thanx as always
Greg
Old May 20, 2008 | 02:59 PM
f35099's Avatar
f35099
Default RE: Unused connector/Tour Pak
You are correct. The male connector is available from the dealer. The body is 73103-96BK (pin housing 3 place) and the pins (you need 3) are 73190-96. You should be able to use it for anything that needs a tail and/or brake light feed.
Old May 20, 2008 | 04:03 PM
Gregte's Avatar
Gregte
ORIGINAL: f35099
Thanx!!! That's just what I thought. Any help on the proper way to crimp the pins onto the wires???
Old May 20, 2008 | 10:06 PM
Harleypingman's Avatar
Harleypingman
Take a look in the appendix of an HD Service Manual--it has excellent pictures and explanations on crimping/installing/removing the wires.
It's also pretty simple to ask a tech at the dealer to do it for you and tip him for the service.
Fry's sells an acceptable crimping tool, Philmore WS26, for 7.99.
gmurdock
Jan 1, 2010 09:03 AM
mastery
Apr 3, 2009 08:30 AM
Gregte
Aug 6, 2007 08:21 PM
oley55
Feb 24, 2007 08:33 PM
