EZ-Brake
Old May 22, 2008 | 08:33 PM
Silverbear's Avatar
Silverbear
Default EZ-Brake
After you install it. what kind of grease did you use thezert. I normaly use lithium but could but new to bikes I do not want to mess it up.
07 Road King Classic.
Old May 22, 2008 | 11:18 PM
roadking1893's Avatar
roadking1893
Default RE: EZ-Brake
I used the same grease I use on my boat trailer wheel bearing. I did that because of the high heat around the brake pedal.
Old May 22, 2008 | 11:47 PM
Manish_Hawg's Avatar
Manish_Hawg
I was supposed to use grease? Where? When? Aww chit.
Old May 23, 2008 | 07:48 AM
roadking1893
I coated the shaft it slide on and then couted the inside bore of the pedal. the unit should have come with a grease fitting after the complete install I pump grease into the grease fitting untill grease started to show. something like when you grease your "balljoint" on a truck.
Old May 23, 2008 | 07:52 AM
Flying Horse's Avatar
Flying Horse
Just grabbed a neighbors grease gun, shot it a few squirts, cleaned her up, then did the trailer axlesand rode off.
Old May 23, 2008 | 07:56 AM
Puzzled's Avatar
Puzzled
I would imagine that just about any grease would be sufficient. It is a matter of using what is in your grease gun. I tend to use Lucas hi temp wheel bearing grease (it is what I use for my enclosed trailers). Same for the neck bearings.
Old May 23, 2008 | 08:31 AM
Q Hog's Avatar
Q Hog
I used the grease gun on my grease pionts.
mi2az
Jul 2, 2011 07:44 AM
jpbo
Dec 13, 2010 03:57 PM
jcanrun
Jun 17, 2009 06:36 AM
raaaaaa
Jun 10, 2007 01:48 PM
deer30084
Mar 31, 2007 09:52 PM
