bad noises....
Old May 25, 2008 | 07:23 PM
classicjade01's Avatar
classicjade01
Default bad noises....
The last couple days starting my bike I've noticed a new noise at idle. It"s sounds like a paint can raddling. It's so loud my wife actually asked what that noise was while riding though town. Also anything over 3k RPM's makes a major racket in the top end....way more than usual. I've rode this bike for 22k miles now, 6k on the gear drive set up, so i'm used to the normal noises it makes. It seams to be coming from the rear jug on the right side. I'm not the easiest on this bike but I do try and take care of it. I'm assuming I might have broke a valve spring or something. Anyone have any ideas or if they are close in the area could come by and have a listen? I'm afraid to ride it to my dealer (60 miles) because I think it might grenade on me. Any ideas?
Old May 25, 2008 | 08:18 PM
sdgrg's Avatar
sdgrg
Default RE: bad noises....
get it checked out ASAP... doesn't sound right. If I heard that sound, I'd stop running it until I knew for sure it was "normal"
Old May 26, 2008 | 06:17 AM
Ram's Avatar
Ram
As you stated it could be a valve spring. Or you could have lost the oil pump and its causing could be causing other issues. If the dealer is that far away, I'd tow it in or have them pick it up.
I don't know how much mechanical back ground you have, but you cold start trouble shooting on your own!
Do you have the FSM? Compression tester or a leak down tester? An oil psi gauge (mechanical) that you can put on the engine to test oil psi? Can you tell if its one or the other cylinder or both from listening?
Old May 26, 2008 | 06:32 AM
detnight's Avatar
detnight
the teeth on my rotor were worn enought that it make a lot of noise (13000 miles) had to replace last week
Old May 26, 2008 | 07:21 AM
chappy_2336's Avatar
chappy_2336
I would definitely check on the outside of the engine first to see if anything is loose, Ive heard noises like this and it ended up being something like the exhaust or one of the many chrome covers coming loose. Good luck, if you cant find it, I would definitely trailer it.
2005UltraNC's Avatar
2005UltraNC
Classic, let us know what you find. I have a simialr noise, though above 4000 rpm's. Seems to get better when hot, takes till 5000 rpm's before I hear it. But, on the other hand, no noticable noise at idle (just a tad when cold for a couple seconds).
I put in feuling lifters - wondering about these guys - any feedback?
Any case, here shortly, pulling the heads off to get compression releases installed.
Old May 26, 2008 | 07:25 AM
electaRICK's Avatar
electaRICK
prim'y chain shoes worn...
cam chain shoes worn,,, if gear driven, maybe bearing
compensator sprocket..
these need checking at your milage
Z
Engine Mechanical Topics
18
Jul 2, 2019 11:21 PM
ShaZAM
2014-2024 Touring Models
13
Apr 5, 2017 08:14 PM
Harley Convert
Jun 18, 2015 10:14 AM
jacksonfdny
Exhaust System Topics
Sep 11, 2012 07:06 PM
ajax1
Jun 1, 2009 04:52 AM
