DYNO Numbers for Baggers???
  #371
Old 02-21-2007, 10:27 PM
apachethunder03's Avatar
apachethunder03
apachethunder03 is offline
Default RE: DYNO Numbers for Baggers???
Correction to previous post. Noticed I had wrong file.
Here is the right pic.
  #372
Old 02-22-2007, 12:20 AM
apachethunder03
And to think I was complaining about my hp & tq with the 510g cams. Why are you getting such low #'s? I would of thought your #'s would be higher then mine since you have the 95" pistons.
  #373
Old 02-22-2007, 01:05 AM
pirateeye's Avatar
pirateeye
pirateeye is offline
2006 FLHTCI
95" w/10.5:1 Weisco
HeadQuarters 0039 Cam
HeadQuarters Stage 3 Heads
Stock headpipe w/ V&H SlipOns
SERT
111hp/114tq
[IMG]local://upfiles/24618/1EDD81D5AD0B48AC98F5B1AFAEC1241D.jpg[/IMG]
  #374
Old 02-22-2007, 08:27 PM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
ORIGINAL: apachethunder03
He has stock cams.
95" doesn't do a lot alone, you have to put the right cam in it to make it come to life.
Steve
  #375
Old 02-22-2007, 10:50 PM
pirateeye's Avatar
pirateeye
ORIGINAL: maineultraclassic
He has stock cams.
Steve
I AGREE! Building a 95" motor with heads/cams that poorly supply an 88 is almost pointless...but the stealer won't tell you that when you come in to spend the money on just the 95" build.
  #376
Old 02-23-2007, 02:05 AM
Biggzed's Avatar
Biggzed
Biggzed is offline
ORIGINAL: fxdean
Wish mine were as good as some here.
2006 Ultra
95" big bore
S.E. AF
Stock pipes
Stock Cam
I am getting a whopping 70.67 in HP and a huge 72.73 in torque.
Plan to add PC111 usb and V&H slip ons. Any other suggestions? 203 CAM? Thanks
The PCIII and V&H mufflers are a good start. I would not waste the money on the 203 cams. Go with the Andrews 26 (preferably the gear drive if you can afford it). Look a couple of pages back on this thread for Allen.M results. You should end up close, although I think he was running a 2-1 FatCat exhaust.
  #377
Old 02-24-2007, 04:57 AM
mazzurco's Avatar
mazzurco
mazzurco is offline
06 Street Glide
Punched to 95
Max Horsepower 115.9
Max Torque105.7
Heads Roland Racing
Cams.575Lift
Pipes Rienhart True Duals
PistonsForged 10.5To 1
Throttle Body 50MIL
Builder Horsepower express
Tuner Horsepower express
Boy is it Fun To Ride Now!
[IMG]local://upfiles/18084/5F2338C292DB4D83A7A7D29E2944B428.jpg[/IMG]
[IMG]local://upfiles/18084/4F8CF01A1D764AE1960053D337833DA4.jpg[/IMG]
  #378
Old 02-24-2007, 12:57 PM
BLACK 3's Avatar
BLACK 3
BLACK 3 is offline
02 Ultra
95" s/tb se a/c w/ness filter
sbc mild ported heads bigger valves (1mm) 600 lift springs spin drop
.0030 cometic h/g 9.7 9.8 c/r 190/190 f/r ccpr
se f/t pistons w/valve relief
andrews 26g cams
r/h t/d
sert
107.5 tq
100 hp
trying to find a way to show dyno sheet
  #379
Old 02-24-2007, 07:02 PM
fxdean's Avatar
fxdean
fxdean is offline
5th Gear
I was not particularily impressed with my considering that my 01 FXD has more torqu and better HP with a 88 cu and a carb.76t 69hp with a SE filter and SE slip ons. Made few jet mods based soley on AF ratio
  #380
Old 02-24-2007, 08:11 PM
jrudicel's Avatar
jrudicel
jrudicel is offline
2006 StreetGlide..600 miles on it. Stock motor, Rinehart true duals, Arlen Ness Big Sucker, SERT. Tuned by Manns Harley in Coulumbus Indiana ... 77.5hp ...82.4 tq.
Quick Reply: DYNO Numbers for Baggers???
