Changing the fork oil!
Old May 28, 2008 | 11:39 AM
chiefparry's Avatar
chiefparry
Default Changing the fork oil!
The manual makes this sound like huge production needing special tools and euipment like a vacuum pump. Is there a simpler way or is this one area that is best done by a mechanic and if so about what is normal costs to have it done?
Old May 28, 2008 | 11:43 AM
petemac's Avatar
petemac
Default RE: Changing the fork oil!
I like to do all the maint I can myself, but I'd have an indy do this when the time comes. Would be nice to watch him do it so I could do it myself next time.
Old May 28, 2008 | 12:02 PM
Lopoetve's Avatar
Lopoetve
it's a pain. I have them do it when I get a new tire.
Old May 28, 2008 | 02:32 PM
jbhawley's Avatar
jbhawley
saw this thread
https://www.hdforums.com/m_1910227/tm.htm
I have an '01 so i just drain and refill. The cartridge types might require the pump method.
Old May 28, 2008 | 02:40 PM
xxxflhrci's Avatar
xxxflhrci
On an '01 with air in the front forks, it is neither a pain or requires a lot of expensive special tools. You can do it in about 15 minutes with a shop vac and about 3 bucks worth of other stuff.
1.) Drain oil from both sides. Put plug back in one leg.
2.) Take valve out of air fitting on rear of bike and put a 1-2ft length piece of 1/4 inch rubber hose on fitting.
3.) Get a metric bolt the size of the drain plug, cut head off, drill out body. Screw your newly made adapter in fork leg. Put a piece of rubber hose on it.
4.) Measure out correct amount of fork oil and put in glass. Put other end of hose from step #3 in glass.
5.) Get shop vac and stick loose end of hose from step #2 in vac hose and seal with wet rag. Turn on vac. Like magic, the oil gets sucked into leg. When the oil is all the way in, unscrew homemade adapter and replace drain plug.
Repeat for other leg.
Old May 28, 2008 | 02:50 PM
petemac's Avatar
petemac
What would the procedure for an '06 RK be?
ORIGINAL: xxxflhrci
Old May 28, 2008 | 02:54 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: petemac
ORIGINAL: xxxflhrci
Well, it won't have a cartridge left leg like the some of the bikes, so that makes it easier. However, it won't have the air like the earlier bikes to make it the easiest. Basically, you just drain the legs, take off the nacelle to get to the fork caps and then take them out so you can pour the oil in. Do it with the bike on a lift so that you take the spring pressure off of the fork cap.
Old May 28, 2008 | 02:58 PM
petemac's Avatar
petemac
Thanks, doesn't sound as tough as I thought it would.
ORIGINAL: xxxflhrci
ORIGINAL: petemac
ORIGINAL: xxxflhrci
Old May 28, 2008 | 03:07 PM
dawg's Avatar
dawg
ORIGINAL: petemac
ORIGINAL: xxxflhrci
ORIGINAL: petemac
ORIGINAL: xxxflhrci
Very easy to do
Old May 28, 2008 | 03:14 PM
Neckball's Avatar
Neckball
That was the process on my '05. New oil made a big difference. Shouild have done it a long time ago.
