PCIII and checked plugs
Old May 30, 2008 | 08:09 AM
bucs012's Avatar
bucs012
Default PCIII and checked plugs
Before I put my Rush and PCIII on I checked my plugs to see what color they were from just running my B&E Mufflers and Big Sucker with the HD richer fuel download. Plugs looked a little lean but pretty good.
I since have put on my RUSH slip on's and PCIII Touring set up that Fuel Moto pre-set for me and road about 50 miles on the hiway mostly. Pulled the plugs to check the color last night and was surprised that they are pretty much the same color. I expected them to be golden/brown or at least a little darker since it is suppose to be running richer. Too cool outside to tell if the bike is running any cooler with the PCIII. I also did the throttle adjustment right up front.
Also an old Hot Rod Head so I am pretty used to pulling and reading plugs to see how she's runnin.
Just some feedback. Kinda surprised.
Old May 30, 2008 | 08:29 AM
barkster99's Avatar
barkster99
Default RE: PCIII and checked plugs
I installed same setup about 1000 miles ago. Haven't pulled plugs (been meaning to) but also suspected I was running a little rich. Especially considering how black/sooty that right pipe is. Glad to hear they look good. I need to check myself.
Old May 30, 2008 | 10:19 AM
llmotorcycles's Avatar
llmotorcycles
Dont expect to get much info from reading the plugs, with fuel we have these days you can only typically use this a guidelines as extreme rich/extreme lean. And for the soot in the pipes if you have the stock headpipe the RH muffler will always be a bit black and the left clean. Unless excessive, black soot is normal, check the pipe in your car. I agree it sure was nice back in the old days when you could tune off plug readings.
Old May 30, 2008 | 04:37 PM
winston chopper's Avatar
winston chopper
Another way to do it take a ride at higher rpm / speed3k 65MPHand cut off the ignition and glide over to the side of the road and pull the rear plug. If you decellerate you get an idle reading. This way you can see you r higher RPM burn. My wrench taught me that one.
Old May 30, 2008 | 04:45 PM
gunrunner's Avatar
gunrunner
Hard to get the tan color with todays fuel, long as there not chalk white and blistered or black and sutty everything should be ok
2011Iron883
Mar 27, 2011 11:04 AM
Turn2HD
Jun 10, 2009 08:51 AM
ubreal
Sep 23, 2008 08:54 PM
FXDB
Exhaust System Topics
Mar 31, 2008 11:33 PM
Whiffleboy
Apr 27, 2006 05:48 PM
