Pulls left?
Old May 30, 2008 | 10:50 AM
swood's Avatar
swood
Default Pulls left?
Bike seems to pull to the left when I let go with both hands.....I don't do this at high speed, but just replaced rims, and it doesn't seem to track straight.....Is this normal? 05' road king, THanks
Old May 30, 2008 | 11:22 AM
bucs012's Avatar
bucs012
Default RE: Pulls left?
Check weight in your saddle bags. More in one than the other and it will pull.
Old May 30, 2008 | 11:25 AM
Sharknose's Avatar
Sharknose
It's not normal. If it didn't do it before you replaced the rims, make the coathanger tool described in the service manual and check your side-to-side rear wheel alignment.
Old May 30, 2008 | 07:50 PM
Aslan's Avatar
Aslan
Mine has a veryvery slight pull to the left. I don't know but left seems to be very common. I have not heard of any bikes pulling to the right.
It is so slight I don't worry about it. I don't do that much no hands riding.
Old May 31, 2008 | 12:26 AM
nb472's Avatar
nb472
I've found mine tracks straight when I ride on the passenger seat with no hands.A trick I learned from a old friend, RIP.
Seriously, I changed my fork oil to SE oil and pumped the forks as described in the DIY section and it now tracks straight. Road crown,weight distribution,windshield alignment,and clutch cable pressure can also be an factor.
Old May 31, 2008 | 05:32 AM
jpooch00's Avatar
jpooch00
That's normal - they all do it!
Seriously though, I think most baggers have this issue. My '03 RK did it and I found many posts on the net that discussed it. I test drove an '08 Ultra and it did it. The problem seems to be that some of the jigs that the MOCO uses to assemble the bikes are not straight. The dealers can re-align the wheels by adjusting the links on the engine (supposedly).
Good luck and ride safe,
John
Dave2945$
Mar 15, 2018 12:04 PM
Benway
Nov 18, 2011 09:01 PM
ajay450
May 16, 2009 05:34 PM
motorups
Jun 21, 2007 09:12 AM
azmcdude
May 24, 2007 03:06 PM
