Chrome Touratech mount for Zumo
Old Jun 3, 2008 | 05:33 AM
Pastor John's Avatar
Pastor John
Default RE: Chrome Touratech mount for Zumo
If you go with the setup that I have, you will need two parts from Touratech:
1. Chrome 1 Inch Handlebar Clamp (GCLMP1) - $15.00 - Chrome Handlebar Clamp
2. RAM Hex Ball (GRAHEX) - $15.00 - RAM Hex Ball
The Zumo 550 comes with everything else that you will need.
Old Jun 3, 2008 | 06:01 AM
Badbagger's Avatar
Badbagger
Looks good... can the mount be easily removed? I'd like to have a quick detach setup so I can also use my Ipod on another quick detach setup.
Going the techmount way with a Powerlet Powerbar is pricey at $300 for the whole setup so I can use either the GPS or Ipod. Did you hardwire the GPS in ?
Old Jun 3, 2008 | 08:19 AM
jarman's Avatar
jarman
Obviously I don't have a picture but on my detachable windshield I replaced the nut on the center bolt in the with a threaded 1" stainless steel ball **** (McMaster/Carr catalogue $12.00)and use it to mount the zumo to. It puts it right in the center of the windshield in either a high or low position depending on where you turn the clamp. Works great and is not exposed to the elements.
Old Jun 3, 2008 | 09:07 AM
calrickster's Avatar
calrickster
Anyone have a nice looking chrome mount suggestion for 1 +1/4" inch bars? I'm thinking about a Zumo 550 also but am installing Wild Ones mini apes on the new bike.
Old Aug 21, 2008 | 08:04 AM
Merlin's Avatar
Merlin
Originally Posted by Stingboy
Does anyone use the Zumo for XM Radio? If so did you mount the antenna under the fairing and what about the AUX cable? I have a 200 Road Glide and would like to add this setup. Also, where to buy the AUX cable in the correct length and with 90 deg ends.
Sting
Stick the Zumo XM hockey puck in the fairing on top of the radio.
I did a ZUMO Powerlet Techmount quick disconnect mount.
To find the correct 3.5mm aux cable see thread below
https://www.hdforums.com/forum/2801104-post.html
Old Aug 21, 2008 | 08:14 AM
Merlin's Avatar
Merlin
See Thread https://www.hdforums.com/forum/2801104-post.html
I have CHUBBYŽ Wild1 WO517 BARS 1 1/4" bars. I can remove the Zumo and the Zumo Bike Mount in under 5 seconds. It don't get wet when I wash the bike and the Zumo bike mount won't grow little feet when I'm parked.
If you don't want to do the Powerlet Powerbar then Techmount makes excellent handlebar mounts. (I'd suggest the 2 1/4" short)
Old Aug 21, 2008 | 08:59 AM
tda69's Avatar
tda69
Looks good. Nice mount.
Lone Watie
Feb 6, 2011 05:12 PM
jensen
Feb 15, 2009 01:16 PM
rfpmal
Apr 13, 2008 08:45 PM
rfpmal
Feb 19, 2008 04:33 PM
cemax12000
Feb 4, 2007 06:34 PM
