Swapping Pipes
Old Jun 1, 2008 | 06:04 PM
papashog's Avatar
papashog
Default Swapping Pipes
I got an 07 Road King Classic. When I bought it, I had the dealership put on the Rush Slipons. I want to change to some other type of slipon that is a little more throaty sounding. Not sure what yet. If I change, are there any other modifications that I will have to do like some type of fuel adjustments. Thanks in advance for your help.
Old Jun 1, 2008 | 06:55 PM
jcbpa's Avatar
jcbpa
Default RE: Swapping Pipes
Well, there are a lot more guys on this forum who are more tech than I am; but if you change to some good pipes you will likely change the breather and then you will need to do fuel mangaement and a good tune. I used the SERT and a great tuner. But TD Bub 7... SERT and the HD Air kit... try it...
Old Jun 1, 2008 | 07:11 PM
Coolhawg6622's Avatar
Coolhawg6622
Did you try removing the packing from the baffle??? Makes a huge difference in sound....
Old Jun 1, 2008 | 07:44 PM
papashog's Avatar
papashog
yea, I took the packing off. It made a slight difference. Don`t get me wrong, it sounds good, I just want a deeper, throatier sound.
Old Jun 2, 2008 | 02:18 PM
Manish_Hawg's Avatar
Manish_Hawg
Do you knowif the dealership did anything else like aS/E Air Cleaner, SERT ordownload?
Old Jun 2, 2008 | 03:14 PM
roxnatwist's Avatar
roxnatwist
I just put on the Rush slip ons with the 2.25" baffles. My bud has an 08Glide with Rineharts. I thought the Rineharts sounded pretty good until I cranked mine up next to his. I don't know if I've heard pipes that were throatier than the Rush. I also put on the V&H Dresser Dualssothat may have contributed to the sound some. I think theysound incredible. Maybe you should try a more open baffle like2.50". Just a thought.
btharris24
Feb 11, 2014 07:21 PM
daivd.glynn
Feb 25, 2008 02:42 AM
mike@nhca.us
Feb 13, 2008 10:21 AM
Deucegurl
Jun 18, 2007 11:00 PM
KenFichtner
Exhaust System Topics
Apr 19, 2006 08:51 PM
