aux lights 2006
Old Jun 3, 2008 | 07:20 PM
buckmas72's Avatar
buckmas72
Stage I
Default aux lights 2006
hello I just purchaseda light bar off a 2006 Electra glide I boughtit off Ebay the HD dealer saidit would workon my 2006 street glide theproblemis the clown Ibought the light bar from took everything inside no bulbs no clips no nothing just 2 wire in eachI would like to know dose anyone knowif is just a lamp that fits in there like the old head lights if so anyone have a number off the back of the bulbI know a lot of the bulbs are made buy Wagner also is there anyone out there that has a wiring diagram for a Electra glide or and a street glide both 2006 thanks Mark[/align]
Old Jun 3, 2008 | 07:33 PM
dowork08's Avatar
dowork08
Default RE: aux lights 2006
The manual has the wiring diagram and a good one at that i think. You can buy different types of bulbs, some are sealed and then you would just have to put some wire spades on, then there are some bulbs that have replaceable light bulbs in them and they come with connectors, and you put them on. So its no biggie youll be fine
Old Jun 3, 2008 | 08:35 PM
Harleypingman's Avatar
Harleypingman
Next time you are at your HD store, go to the parts counter and ask to see the parts book for the 2006 Touring models and check out the differences in the SG and Electra Glide pieces. Your post is very vague about what parts you received with the light bar--the pictures in the parts book will show you what should be there for the passing lamps. Also, if you plan to retain the bullet turn signals in their present location, you will need to stack the EG light bar and the turn signal brackets on your SG. If you plan to change the turn signal location, youmay need to buy different turn signals since the bullets on your SGprobably won'twork on an EG light bar since they mount differently. Hope I'm wrong--but you really need to check a parts book to see what parts should be there and compare it to what you bought.
clap
Dec 26, 2016 02:11 PM
steelerdude1
Touring Parts
Oct 9, 2014 11:51 PM
raaaaaa
Jun 29, 2009 08:55 PM
crashbike310
Dec 25, 2007 11:58 PM
bzzrd2
Jul 14, 2007 09:39 PM
