IED/XiEDs and the '08 Models, Causing Error Codes?
Old Jun 6, 2008 | 12:13 PM
badbs101's Avatar
badbs101
Default IED/XiEDs and the '08 Models, Causing Error Codes?
How many IED/XiED users with '08 models are getting error codes.&nbsp\\; I've read about it and am wondering how common it is and if it is just the XiEDs or both the IEDs and XiEDs that are causing the problem.
Old Jun 6, 2008 | 02:12 PM
bezoar's Avatar
bezoar
Default RE: IED/XiEDs and the '08 Models, Causing Error Codes?
I have XiED's and no code issues.
Old Jun 6, 2008 | 03:07 PM
confused's Avatar
confused
No codes here on a 08 Ultra
Not to hijack but can you run a fulsac system with the Xied
No A/C or mapping, just the fulsac
Old Jun 6, 2008 | 03:33 PM
LUBA's Avatar
LUBA
How do you know if you set any codes?&nbsp\\; Does the engine light blink or something?
Old Jun 6, 2008 | 03:36 PM
Potato73's Avatar
Potato73
6th Gear
Hi, are&nbsp\\;IEDS ok for OEM catalyst mufflers or they cause any problem&nbsp\\;in&nbsp\\;duration/life of the catalytic converter ?
&nbsp\\;
Thanks, ciao
Old Jun 6, 2008 | 03:52 PM
nycfxdl's Avatar
nycfxdl
From what I understand, the connectors must be snapped in tight. You may want to re seat the connections and that may keep the codes away.
Old Jun 30, 2008 | 01:28 PM
Potato73's Avatar
Potato73
6th Gear
ORIGINAL: Potato73
Hi, are&nbsp\\;\\\\\\;IEDS ok for OEM catalyst mufflers or they cause any problem&nbsp\\;\\\\\\;in&nbsp\\;\\\\\\;duration/life of the catalytic converter ?
&nbsp\\;\\\\\\;
Thanks, ciao
Old Jun 30, 2008 | 01:43 PM
BlackBagger's Avatar
BlackBagger
No codes and I have an 08 StreetGlide
Old Jun 30, 2008 | 04:16 PM
smokin's Avatar
smokin
2008 SG with SEAC and Supertrapp slip-ons - IED's ....no codes
pretty happy with it actuallySmokin
Old Jun 30, 2008 | 04:24 PM
Londonbike's Avatar
Londonbike
The only code I get is for the cruise control and it doesnt work very good any more.&nbsp\\; Going in for warrenty repair on Wed.
