2007 upgrade vibration
Old Jun 16, 2008 | 07:28 AM
katobird's Avatar
katobird
Default 2007 upgrade vibration
installed true duals,k&amp\\;n and fuelpak.
it seems to vibrate up to about 300 rpm
&nbsp\\;
everything is tight, everything has clearance.
&nbsp\\;
i understand the ids would help
&nbsp\\;
jusat seems to vibrate a little more than when the stocck system was on
&nbsp\\;
anyone else see this?
Old Jun 16, 2008 | 07:36 AM
bsharris's Avatar
bsharris
Default RE: 2007 upgrade vibration
I haven't seen this myself, but I heard of someone else complaining of the same issue and finally discovered that the mufflers were slid either in too much or out too much and the hanger bolts under the bags were at the limit of there adjusting or "sliding" area, causing the sliding hanger bolts to vibrate against the mount itself. I hope this helps.
Old Jun 16, 2008 | 08:06 PM
chappy_2336's Avatar
chappy_2336
+1 check muffler alignment
Old Jun 16, 2008 | 08:15 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
motor mounts look good? another is crank runout
Old Jun 16, 2008 | 08:52 PM
dirtdobber's Avatar
dirtdobber
Double check to make sure the mufflers are in the center position on the hanger. If it is too far forward or rearward you will have vibrations.
txfxstrider's Avatar
txfxstrider
Bike should not be running below 300 rpm.[X(]
Old Jun 21, 2008 | 06:51 AM
katobird's Avatar
katobird
THANKS
&nbsp\\;
PROBLEM WAS L/H PIPE SLIDING BACK HITTING THE MOUNT.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
mulch63
EVO
Aug 1, 2008 02:58 PM
Binny
Jul 11, 2008 09:07 AM
Jonny Cannon
Jun 24, 2008 05:05 PM
DamifIknow
Jun 22, 2008 08:54 AM
meancana
Jun 15, 2008 07:29 PM
