Street Glide Tri-Bar Light Upgrade?
Old Jun 18, 2008 | 12:00 AM
Harleypingman's Avatar
Harleypingman
Default RE: Street Glide Tri-Bar Light Upgrade?
ORIGINAL: rickxx
isn't there a mod to make the current running light a brake light by just moving the pin connection?
&nbsp\\;\\
&nbsp\\;
EDIT:&nbsp\\; I don't recall the color-code of the wires in the SG facia LED connector that plugs into the TP wiring harness.&nbsp\\; However, the TP harness has three wires:&nbsp\\; black for ground\\; red/orange stripe for brake light\\; and, blue for run light.&nbsp\\; In the SG connector, leave the wire in the socket that connects to the TP connector's ground wire, and remove the other pin/wire from the SG connector to correspond with the red/orange wire in the TP connectorslot 2, IIRC.
Old Jun 18, 2008 | 02:49 AM
onlythebest's Avatar
onlythebest
Here you go. I had this in photobucket for something else.
Old Jun 18, 2008 | 06:58 AM
StreetGlideMedic's Avatar
StreetGlideMedic
Anyone got a manufacturer and part number for this?&nbsp\\; Harley...Kury?&nbsp\\; Mike
Old Jun 18, 2008 | 09:15 AM
PHREDD71's Avatar
PHREDD71
ORIGINAL: Harleypingman
ORIGINAL: rickxx
&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
YesMove the wire from socket 3 to 2.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
&nbsp\\;\\\\\\;
I just tried this and all it did was cause the license plate light to turn off when I applied the brake. The tribar did not change??? I also tried moving the 1 pin to the second position. I got the same result. BTW, I have an 08 FLHX.
Old Jun 18, 2008 | 04:58 PM
divertim's Avatar
divertim
[quote]ORIGINAL: StreetGlideMedic
Anyone got a manufacturer and part number for this?&nbsp\\;\\\\\\; Harley...Kury?&nbsp\\;\\\\\\; Mike
/quote]
I would like to know where to get one also
Old Jun 18, 2008 | 05:28 PM
garyhendley's Avatar
garyhendley
go to kury,s website there is all kinds of choices for led
Old Jun 18, 2008 | 05:58 PM
HRLYSG's Avatar
HRLYSG
&nbsp\\;
H-D part number 68358-07
&nbsp\\;
&nbsp\\;
Thanks for the pic "onlythebest."
Old Jun 18, 2008 | 06:01 PM
marvincbr's Avatar
marvincbr
It's a HD part&nbsp\\; 68358-07.&nbsp\\;&nbsp\\;
Old Jun 19, 2008 | 07:52 AM
PHREDD71's Avatar
PHREDD71
ORIGINAL: rickxx
&nbsp\\;\\\\\\;\\\\
&nbsp\\;\\\\\\;
EDIT:&nbsp\\;\\\\\\; I don't recall the color-code of the wires in the SG facia LED connector that plugs into the TP wiring harness.&nbsp\\;\\\\\\; However, the TP harness has three wires:&nbsp\\;\\\\\\; black for ground\\\\\\; red/orange stripe for brake light\\\\\\; and, blue for run light.&nbsp\\;\\\\\\; In the SG connector, leave the wire in the socket that connects to the TP connector's ground wire, and remove the other pin/wire from the SG connector to correspond with the red/orange wire in the TP connectorslot 2, IIRC.
&nbsp\\;
I am no expert, but I would like to try and see if I can figure this out with your help. I understand what you are saying, but I do not see how to make it work without putting a jumper wire or something. In order to be able to talk more clearly about this, I have attached a copy of the electrical diagram from the service manual for reference.
&nbsp\\;
http://i152.photobucket.com/albums/s...ingDiagram.jpg
&nbsp\\;
There are only two wires on the tribar light connector, and both are black. The brake light is a whole seperate connector below the tribar connector. So how do you tap into the red wire from connector 3 on&nbsp\\;the brake connector so that you can activate the tribar light when you apply the brakes?
&nbsp\\;
Thanks for your patience!&nbsp\\;
[IMG]local://upfiles/60631/977BBBBF199243AD9F1E15B60175D4D2.jpg[/IMG]
Old Jun 19, 2008 | 09:04 AM
Harleypingman
Move the wire in the tri-bar connector that currently connects to the blue (run light) wire in the TP harness to the empty chamber so that it connects with the red/orange wire in the TP harness.&nbsp\\; The TP connector is shown on the main wiring harness diagram in the SM.
&nbsp\\;
The wiring diagram you posted is irrelevant for this mod since the tri-bar LED doesn't use the wiring in the diagram on an SG.
