Sat radio volume
Old Jun 17, 2008 | 05:06 PM
bigdoghd's Avatar
bigdoghd
Default RE: Sat radio volume
Nooo I just ponied up for a factory XM unit I hope I dind\\;t make a mistake. It's loading right now and my tech is saying that the reception is fading in and out. I put the ant on top of the dash instaed of under the fairing. I sure hope this wasn't a waste of money.
Old Jun 17, 2008 | 08:18 PM
07BlkCherryUltra's Avatar
07BlkCherryUltra
You're gonna hafta keep us posted there bigdoghd.&nbsp\\; Just as soon as the two companies merge I'm looking into getting the in-dash XM.&nbsp\\; But not if it's going to be a POS.
Old Jun 19, 2008 | 12:54 PM
henryjw1's Avatar
henryjw1
Had mine installed two weeks ago. It is the HD XM unit. Antenna is mounted inside the fairing. Sound is same as CD or FM. Works great.
Old Jun 19, 2008 | 06:16 PM
gasman1075's Avatar
gasman1075
i went to a sony from biketronics with the add on xm it works great when i had the stock harmon kardon i couldnt get any volume either now it works great with no amp i also like the built in mp3 player in the faceplate you just pull it off hook it to your computer put on 240 songs and away you go
Old Jun 19, 2008 | 09:25 PM
bigdoghd's Avatar
bigdoghd
Installed it a few day ago and ran the ant to the top of the dash. It tucks in great right by the windshield. I felt it would get better reception. I'm not sure if it's a volume issue or it just does not have that great od a signal. I do feel that it sounds weak. I'm going to have to try and switch back and fourth and see. The radio selection is awsome.
Old Jun 19, 2008 | 11:23 PM
maxum96's Avatar
maxum96
I put a $5 (that's right, $5 after rebate) add on XM receiver on my dash.&nbsp\\; I put the power adapter under the fairing and hardwired it in instead of in the cigarette lighter.&nbsp\\; I ran an output cord inside the fairing and in to the AUX input on the front of the stereo so the cord wouldn't be draped across the dash.&nbsp\\; I have the HD windshield 3 bags on top of the dash.&nbsp\\; The bags are mounted on a piece of steel. I put my XM antenna between 2 of the bags.&nbsp\\; Unless you look for it, you don't notice it.&nbsp\\; I did have it sitting on top of the radio inside the fairing, but I wasn't real happy with the reception.&nbsp\\; No issues with the music volume level.
Cuff
Jul 20, 2008 10:36 AM
mestude
Jul 4, 2008 11:40 AM
Baffler1
Jul 1, 2008 02:04 PM
acid_chipmunk
Jun 27, 2008 08:43 AM
Getyurmotorunnin
Jun 13, 2008 01:13 PM
