Shock Pressure
Old Jun 18, 2008 | 08:59 AM
rsofa's Avatar
rsofa
Default Shock Pressure
I was wondering what you guys run for shock pressure loaded 2up on the Ultra????
Old Jun 18, 2008 | 09:08 AM
bezoar's Avatar
bezoar
Default RE: Shock Pressure
My Road King suggests 30lbs. It would tell you in your owners manual.
Old Jun 18, 2008 | 09:14 AM
Fletch's Avatar
Fletch
With the wife and I up ( along with all her stuff!) I have to run close to 50 lbs to keep from bottoming out. I know, that's more than HD lists as max pressure. You gotta do what you gotta do!&nbsp\\;
Old Jun 18, 2008 | 09:19 AM
BadBobOk's Avatar
BadBobOk
ORIGINAL: rsofa
&nbsp\\;
Depends on the size of your wife's ***.
Old Jun 18, 2008 | 12:11 PM
rsofa's Avatar
rsofa
ORIGINAL: BadBobOk
ORIGINAL: rsofa
&nbsp\\;\\\\\\;
Right hand left hand or BOTH??
Old Jun 18, 2008 | 03:34 PM
Buzzsaw's Avatar
Buzzsaw
Depends on whether you have the stock or Low profile shocks, different&nbsp\\; max pressure.&nbsp\\; The stock are I believe 30 psi and the low profile are 50 psi.&nbsp\\; I am a husky guy, so I run the low profiles solo at about 30 psi and 2 up around 40 psi.&nbsp\\;No bottoming out problems.&nbsp\\; All depends on how much you and the other rider weigh and what type of ride you are looking for.&nbsp\\; I would suggest play with some different settings on the same ride to figure out what works best for you.
&nbsp\\;
Scott
2007 EGC
IDS
Old Jun 18, 2008 | 03:36 PM
garyhendley's Avatar
garyhendley
i run 2 up with 30 lbs my wife is 95lbs and i am 185 and thats with a full packed load too
Old Jun 18, 2008 | 03:55 PM
Odd Job's Avatar
Odd Job
I'm 215, wife is 130, bike loaded, I run 25-28 pounds...rides like a dream and soaks up most bumps and humps, haven't&nbsp\\;bottomed out. 30-35 pounds found ride is too harsh.
Old Jun 18, 2008 | 04:03 PM
JustLoafin's Avatar
JustLoafin
Finding the right pressure is certainly a proccess.&nbsp\\; I find myself at or slightly above the max pressure as weight becomes an issue.&nbsp\\; How heavily we are loaded, road conditions and how "spirited" of a ride we are on all play into the equation.&nbsp\\; Consider a hand pump for road side adjustments.&nbsp\\; If you are bottoming out try a few more pounds.&nbsp\\; If you are already above the max pressure and still having problems you may want to consider aftermarket shocks.&nbsp\\; Just a few thoughts.
Old Jun 18, 2008 | 04:44 PM
Moe Taters's Avatar
Moe Taters
On my 2000 Road King I run 35lps in rear riding solo.&nbsp\\; Run 50 lps running two up.&nbsp\\; I am somewhat north of 400lps, wife is a svelt 175lps.
&nbsp\\;
Hope that helps.&nbsp\\; Moe Taters, Carlin Nevada
