Is there anyone that is building an auto trans for an HD? \\; A friend of mine is handicap and has an Electra Glide Trike, but is having a difficult time shifting and needs the brakes moved over to the left side. \\; Any ideas?
Look into a centrifugal clutch, like the Revloc or others out there some are better than others, I have also heard of a power shifter push the button for up or down and it does it for you. \\;I actually saw that on this site somewhere, \\;just don't \\;remember where.  \\;I know Ridley makes an Automatic, don't know if it will fit on the HD. \\;
Hope this gave you some ideas.
Scott
2007 EGC
IDS
I've never heard of an automtic gearbox for a Harleybut there are devices that will help you shift.
Check out Kliktronic (ww.kliktronic.co.uk), this might be the solution for your friend.
Good luck,
Dries
 \\;it is a simple bolt on the makes the bike work like a go cart they work well our local deal sets a few bikes up like that from time to time for people
