This '06 Ultra is the only vehicle that I have ever owned that does not tell how much oil it holds. I can't find anything in the SM either. What's up with that and how much does your TC88 hold?
It is in the owners manual.It says 3.5 qts but it usually takes a little more to get to the full line on dipstick.I put in about 3 3/4 on my last oil change
Do you know how to use a dipstick
Start with 3 quarts and take it from there (do NOT overfill)
3.5 qts means 3.5 qts. NOT 4- \\;Oil level should be to the middle on the dip stick. Not the top. If you over fill it you may get oil blow by into your air cleaner.
